Twin charger 301 |
190xt llss
Topic: Twin charger 301Posted: 08 Jan 2019 at 5:31pm |
I’m building a llss 190xt with a 301 I’m looking for suggestions on a twin charger setup
Acllss puller
Posted: 08 Jan 2019 at 7:49pm |
Call Dennis at FVP !!!! Smalll s400 and a gt45 on top maybe, just call him .
Acllss puller
Posted: 08 Jan 2019 at 7:52pm |
Head and flow will be your problem . Can be improved with extreme work !
DrAllis
Posted: 09 Jan 2019 at 7:23am |
WHAT ARE YOUR RULES ???? Some organizations only allow a maximum inlet/outlet size !!
190xt llss
Posted: 09 Jan 2019 at 8:14am |
I can run any two turbos. No intercooler. Water injection. I might add I’ve already got the head work done and custom exhaust and intake housings to let it breathe better.
DrAllis
Posted: 09 Jan 2019 at 9:55am |
So, how many CC's of fuel and what type of injection pump and injectors do you have? You can run bigger turbo's with 1000 cc's versus 700 cc's of fuel. I assume you are open RPM's ??
190xt llss
Posted: 09 Jan 2019 at 10:12am |
P-3000 capable of 760cc 4x30 injectors yes open rpm
bsallis180
Joined: 29 Jul 2013 Location: Pennsylvania Points: 209 |
Posted: 09 Jan 2019 at 10:38am |
Doc no intercooler? Over 1000cc on 301inches?
DrAllis
Posted: 09 Jan 2019 at 12:18pm |
So a 190XT with any size twins and 760 cc's of fuel should need a gear waaaay faster than direct drive road gear ? Yes or No ?? Under 7000 lbs ??
190xt llss
Posted: 09 Jan 2019 at 12:30pm |
10% over road gear 6400 lbs
190xt llss
Posted: 09 Jan 2019 at 12:31pm |
If I can build the power for a faster gear then that’s where I’ll go
DougG
Posted: 09 Jan 2019 at 4:53pm |
Any videos? Sounds like a good one
Acllss puller
Posted: 09 Jan 2019 at 10:01pm |
Power to be had with the newer injectors with 5 hole or even 6 hole !
KevinON
Joined: 07 Dec 2009 Location: Schomberg, ON Points: 810 |
Posted: 11 Jan 2019 at 8:26am |
Best of luck in your build! I am building a 7000lb Super Light Mod Farm 190XT right now, but my next build will be a twin charger 301. Cheers.
Acllss puller
Posted: 16 Jan 2019 at 6:18pm |
A 180 in direct is 22.7 you should be able to get at least that fast 21.6 would be good if your doing it all ? Good luck
190xt llss
Posted: 16 Jan 2019 at 6:40pm |
I’ve got 10 over gears and going with 20.8’s
