Allis CA with B Finals
1955allisca View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955allisca Quote  Post ReplyReply Direct Link To This Post Topic: Allis CA with B Finals
    Posted: 24 Sep 2017 at 4:53pm
Has anyone installed B finals on a CA to lose weight and make narrower? Just wondering if the final gears are the same ratio or how much faster or slower it goes and was hoping on a weight difference if anyone's done it thanks in advance.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2017 at 9:53pm
No weight savings being the B finals aren't set up to adapt light steel wheels.  Save weight by bolting on D10/ A Farmall Steel wheels with plain rims .to CA final drives.
Edited by Ken in Texas - 24 Sep 2017 at 9:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955allisca Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2017 at 10:00pm
I'm running farmall centers now, I know Bs have cast centers I was going to make a 6 bolt hub to put on. I was also looking into changing the bull gears and then I think the hub from a CA may go in a b final but not real sure until I tear either apart. I know a B doesn't have a hand clutch in the axle and it's more than a foot narrower. They are also about 600lbs lighter than CAs and the rearend is really the only difference I can tell just trying to get down around 2000 empty
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 6:08am
A B made after SN 18054 should have the same hub as a C.  According to the parts book anyway.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 10:57am
B flanged Axle part number 212806
C flanged Axle part number 210220
    Different part numbers don't interchange according to my parts book anyway
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 12:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 2:25pm
There is one more if you use the first B axle stub with the splined 5 stud adapter hub,
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 4:11pm
Maybe I should have specified, they use the same center for the hub.  Looked that up 30 seconds before I had to leave for work and didn't get to research it in depth.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 5:00pm
Ratios are different.  Things will bolt up if you make provisions to change the fender mounting rails.  However the one that said use D10 finals, that will not work. B,C & CA have out board band brakes, whereas the D10/12 have inboard shoes and the bolt pattern is different.
This page was generated in 0.189 seconds.
