Gear for the 185
zulawski87 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zulawski87 Quote  Post ReplyReply Direct Link To This Post Topic: Gear for the 185
    Posted: 03 Aug 2016 at 7:55pm
Hey guys. Just an opinion or hopefully some experience would be nice. I have a 185. Dynoed last night at 138 hp. 18.4x30 firestone field and road rears with matching band duals. Inner filled with fluid. Will be pulling in 9500# since I can not make 7000# class anymore with the fluid. Will I still be able to go in third hi or low or am I down to second gear now? Thanks for any advice.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2016 at 8:23pm
At 138 hp, I assume it has an aftermarket turbo and some pump/injector work? If so you, should be able to use third high/low (fifth and sixth) easily.
I, personally, never had any luck pulling with calcium chloride in the tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote zulawski87 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2016 at 8:26pm
I have beet juice but I know what you mean. I use it on the farm and need the weight. Just pulling at the county fair for fun.
Post Options Post Options   Thanks (0) Thanks(0)   Quote zulawski87 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2016 at 8:34pm
Sorry you asked a question.... yes I have a 200 turbo and pump and injectors are setup up at 200 specs at local shop. I'm just lucky to be at 138 hp. When I overhauled the engine I was expecting 100_110 hp
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2016 at 10:09pm
Second gear, but I'm not there looking at what kind of track you've got, but I still think second.
Post Options Post Options   Thanks (0) Thanks(0)   Quote zulawski87 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2016 at 10:12pm
Track is usually hard clay. Makes my wd work in 4000#. Good traction
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2016 at 10:30pm
from memory - it takes about 160 hp to hold 3d high with 30" tires at 7000 #. On a power track you are in 4th gear over 8000#....
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2016 at 10:47pm
Pull with duals??
Post Options Post Options   Thanks (0) Thanks(0)   Quote zulawski87 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2016 at 8:41am
Thanks guys. I was undecided to go in 2 hi or 3 low. Looks like it's a toss up yet with the answers lol Friday night I'll try one or the other
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2016 at 8:59am
Not to sidetrack, but on Facebook there is a post about a guy running a 185 with 200hp.
Intercooled, not sure what Turbo setup
But he farms with it.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2016 at 4:31pm
Go 2nd high side, it sucks to run out of power,,,,, and remember to watch the track before you pull,, ,
Post Options Post Options   Thanks (0) Thanks(0)   Quote zulawski87 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2016 at 10:01am
Well I went in 3 low. Just barely spun the tires at the end. But still took 1st. Beating a 1206 by a foot. So mission completed. I beat the annoying red ones. Thanks guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2016 at 10:49am
Hey alright!! Luv to see the Orange take the 1st spot over red and green!
