power director
200 allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Topic: power director
    Posted: 04 May 2016 at 7:17pm
Does anyone have a diagram on how to delete power director and still use hi and low
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2016 at 8:03pm
The power director is the high and low.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2016 at 8:18pm
I want to make it mechanical shift
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2016 at 8:45pm
If you eliminate the hydraulic power director. Then you have to replace it with the coupler to lock the shafts together Or a small gearbox but you have to stop and change gears.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2016 at 6:54am
I looking for a coupler would prefer hi and lo but low would be good for now
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2016 at 7:06am
Need to get a hold of Mac on her he has them
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2016 at 9:19am
I think DR Allis, or OPS heads has what you need. How much power were you still getting away with using the PD still?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2016 at 9:21am
Mack sells mechanical boxes for 190
found it
here is what Mack is selling
Edited by CAL(KS) - 06 May 2016 at 9:30am
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2016 at 12:21pm
If you want the use of both the high and low range but do not want the issues of a potential P.D. clutch failure or slippage contact Dr. Allis. This is not an on the go shift, but you can choose either high or low range. Mack's gearbox eliminates low range but either speeds up or slows down the remaining 4 gears. Just depends on what you want to do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2016 at 6:12pm
I want to eliminate powe director so I don't have problems down road I would like to use hi and lo to keep my options open but right now just running 7th gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 10:31pm
It is wise to get rid of PD clutch. With RPMs it is a bomb waiting to expand.    MACK
