AC 720 restoration progress
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Topic: AC 720 restoration progress
    Posted: 19 Apr 2016 at 5:02pm
A couple of progress pictures of my AC 720 restoration. I have added a Vega power steering. Hoping it works as expected. I'm currently installing all the wiring that I got from Steve at B&B Custom Circuits. Man, there is a lot of wires to hook up. Hope to have the tractor with the Ark 700 loader done for the summer shows.
Edited by mnoonan-NEWI - 19 Apr 2016 at 5:03pm
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2016 at 7:18am
looks sharp
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2016 at 7:49am
That is very nice, looking like new.
Can you give more detail on the power steering?
I have heard that the manual box for the 720 was from the Vega. Does that mean the power assist box is the Vega optional power assist box?
The hydraulics to run it, will that be from the main pump?
What are those rear tires (make, size)?
Keeping the original engine?
structures View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2016 at 8:28am
Wow.  Looks great.  Keep posting pics.
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2016 at 8:58am
nice to see another 720 being updated, should last near on forever
Hey, what is that modified B in  the background?
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2016 at 10:53am
Brian, John and others,
The power steering box was a new unit purchased from CPP and I bought it with the optional cast pitman arm. Here is an EBAY link;
This box will bolt up to the existing mount holes exactly however you must cut the mount plate out and move it back about 1/2"-5/8" and tilt the top slightly forward and up about an 1/8" so that it doesn't project thru the bottom floor panel. You will also need to make a couple of other minor modifications.
The original steering universal joint will need to be replaced with (2) smaller ones cut to fit and welded together. The length of the new u-joint will be about 1 1/2" shorter than original u-joint.
The hole through side frame will have to be moved back to accommodate new location of the pitman arm.
No changes to the steering shaft are required.
The following pictures will show how the CPP unit fits when bolted up after modifications.
On the hydraulics, I removed the original pipe from the charge pump and ran a new hyd. hose from the charge pump to the input port of the ps box and another new hyd. hose from the out port of the ps box to the main control valve in port.
A side note though-I do not have the engine in yet to test this all out, but have been told by reliable folks that this will work.
Rear tires are Good Year Terra Tires with Super Terra Grip 31 x 15.5 - 15.
Engine is original.
The other Persion Orange #1 project you see in the earlier picture is my little hot rod with a Flathead V8 but that's another story.
Feel free to contact me for further information on my projects and thank you all for your interest,
Mike
ac720nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2016 at 3:31pm
SWEET, would love to see in person
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2016 at 8:47pm
As I said on the phone Mike, that 720 looks sweeet!  Love the p/s to! That should be pretty slick!  Great project. Love the Hotrod....!
Steve@B&B
V2Inc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote V2Inc Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2016 at 6:51pm
Both tractors look Assume, absolutely inspirational.
Allis Chalmers 616 w/60" Blade, 48" Rotary Tiller & Plow - Cool Man Stuff
GlenPettit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenPettit Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2016 at 8:18am
Fantastic restorations, you are doing really great work.
Sure look like they have returned to "factory new".
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 9:58am
Thanks to all for the kind comments.
Mike
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 6:36pm
nice looking work,    what is the powertrain on the v8?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 9:42pm
The engine is a 1949 Ford flathead V8 (100hp) converted to 12 volt. It drives a 1983 Case 226 garden tractor hydraulic drive and has a power steering unit from a Yanmar compact tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2016 at 7:00am
Mike,
 You custom guys just drive me crazy with your excellent work! My brain just cant do that type of detailing! I can barely get them scrubbed up as original. Maybe I just don't have the smarts to begin with!:) That custom hot rod B needs to be a thread by itself! Just awesome! Thanks for posting! Looking forward to more of the 720 and the B too.
acken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acken Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2016 at 12:13pm
Looking good Mike, will probably see it in Portage, or Hutch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2016 at 10:31pm
More progress pictures. Power steering works. Electric fuel pump added.
Have a few final minor issues to work out, then decals to be added and then get the Ark 700 loader mounted and then she will be ready for the summer shows.
I hope you all like it.
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2016 at 7:08am
what fuel pump are you using?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2016 at 9:23am
Dave, the fuel pump is;
Facet Electric Fuel Pump 40100N Kit w/ model 40106 Facet Box
$54.60 from Find it Parts  888-312-8812
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2016 at 9:27am
thanks
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2016 at 11:52am
Where is the post showing the flatty running? Sounds so good I'd like to hear it running again. Thanks for going to the trouble of posting the pics. and letting us see the good work and imagination it takes to build these things.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2016 at 12:01pm
You know, I just got to thinking. We have a early '41 C that we are planning to restore, yet after looking at yours there may be a change in plans. A little custom work may be in order after the '65 Rivera is done. (Getting close)
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2016 at 12:06pm
Here is a link to a couple of video's and thanks for asking;
https://www.youtube.com/watch?v=ScEIOdyUwuE
https://www.youtube.com/watch?v=aml2JK5mWDQ
Leon, if you decide to build one of these, I would be happy to share my information & experience.
Edited by mnoonan-NEWI - 06 Jun 2016 at 12:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 8:56pm
More 720 progress pictures.
It is all done except for decal on back of seat which is on order and the Ark 700 loader which I will hopefully get installed next week. Hope to have it all done for the Indiana GOTO. I will post more pictures then.
Thanks for looking,
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 9:11pm
Nice job! What size and brand rear tires? Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 9:15pm
Tracy, They are Good-Year Terra-Tire 31x15.5-15.
Edited by mnoonan-NEWI - 08 Jun 2016 at 9:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 9:15pm
Wow does that loooooook Nice! You do a fantastic job on you tractors! Thanks for posting!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 10:00pm
Looks awesome Mike!  Are you going to take it to Hutch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 10:05pm
Myron,
Yes, I will have it at the Indiana GOTO hopefully with the loader attached and at Hutch.
Hope to see you there.
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2016 at 12:04am
Mike, are they still available? Look sweet. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2016 at 4:57am
May just have to go to Indiana to see this thing, nice
This page was generated in 0.398 seconds.
