Wanting to build a new puller this winter |
48ACWD
Joined: 06 Jan 2013 Location: Pennsylvania Points: 208 |
Topic: Wanting to build a new puller this winterPosted: 22 Aug 2015 at 3:22pm |
Hi, I just started pulling over this summer in the 3000lb stock farm dead weight classes locally. I have a 38 unstyled wc with a 201 1950 wd engine in it. It's all stock and I want to become more competitive next season. I really hate the hand brakes it's hard to pull them when you have to work the throttle and steer so.. what should I build I would like to pull in dead weight and transfer classes was thinking 4500 to maybe 6000. I have a wd chassie I just got a gleaner E M code motor as well. Please any help would be appreciated. Thank you
DrAllis
Posted: 22 Aug 2015 at 4:22pm |
I can't imagine a WD being very competitive starting out at 4500 pounds and going up to 6000 pounds?? A WD isn't too hard to make weigh 3500 lbs or a little less.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5323 |
Posted: 23 Aug 2015 at 11:44am |
My narrow front end WD 45 goes in the 3500 with me (~300 lbs.) on it. I have removed the platform, rock shaft, lift arms, belt pulley, hydraulic cylinders and PTO shaft. I have rear rims from a D-17 and 16.9 x 28 rubber.
You could also remove the hand clutch, hydraulic pump and (maybe) the PTO gearbox. I have been told the WC narrow front is much lighter than the WD/WD-45 narrow front. You won't have much moveable weight in the 3000 lb. class, so you may want to have a lot of room for adjustment in your hitch, to balance the tractor. Edited by WF owner - 23 Aug 2015 at 11:48am |
Ken(MI)
Joined: 14 Sep 2009 Location: Lansing, MI Points: 619 |
Posted: 24 Aug 2015 at 8:30am |
A WD is a great 3500 lb. dead weight tractor, but you will need to put it on a weight loss program to get it there, as mentioned above. With a stock engine, it won't do 4500, Gleaner E will get it there, biggest problem is balance and tires, you can go to 38" rubber, but the gearing is too fast for dead weight. The WC gives you many more options, as you can run 36" tires, lower gearing is easily available, and if everything is right, with a properly set up early un-styled rear end, you shouldn't need to reach for the brakes, upgrade the engine and it's a great tractor from 3000 through 4500 in dead weight.
48ACWD
Posted: 25 Aug 2015 at 8:04pm |
I have the chance to buy a 34 unstyled wc. Would this tractor have the lower rear gears and if so would this be a better candidate for the Gleaner E motor. I would really like to get into doing some transfer pulling as well, will I have the power I need turn 36 or 38's in the 4500 class? Thanks
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6386 |
Posted: 26 Aug 2015 at 5:50am |
I just pulled last night at our local fair in 5000 farm class (Big sled) with the WD (E Z Code and 13.6x38's) and I ran out of power way before the end. My stock D17 put 75' on it.
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
48ACWD
Posted: 26 Aug 2015 at 7:41pm |
I don't have a lot of money to spend on this build as I need to buy weight as well and we all know that's pricey. So can anyone tell me which way I should go with this. I have a E M code motor a wd chassie a RC rolling chassie and a 38 Unstyled WC that I'm using in 3000 dead weight class and a low serial 34 unstyled wc Im interested in buying. I have options but don't know the pulling ways with these AC tractors. Without actually building a engine to make lots of power will this M code with any of these chassis get me anywhere in transfer pulling. We start at 4500 class in this western style pulls. Thanks any info will help
Gary in da UP
Joined: 13 Sep 2009 Location: EUP of Mi. Points: 1885 |
Posted: 26 Aug 2015 at 8:34pm |
Use the RC chassis with the M engine , look for a V code G226. If your starting at 4500 and wanting to go heavier a D17 would be more better.
Ken(MI)
Posted: 27 Aug 2015 at 5:00am |
It depends on your local rules, around here, most dead weight clubs have rules that hold you to original tire diameters, so a WC must run 24, 28, or 36 inch rubber, an RC is limited to 28 inch, and the WD would be 28 and 38. Our transfer clubs allow more room to work in that area and allow 38's on just about anything. With what you have to work with, I would take the RC ring and pinion and put it in the early styled WC chassis with the M motor and 38 inch rubber if allowed, that combination will do a reasonable job for everything you are trying to accomplish, and you should still be able to make 3000# if you desire. Around here if you use the RC rear end, the tractor is considered an RC, it is considerably lighter (about 200#) than the early WC rear end, and no where near as durable, the lightest rear end housings are the RC and late WC with the welch plug in the center of the housing, the very heaviest are the early ones through about mid 1936, over 140# heavier, just in the housing, and the RC has a lighter differential, axles, hubs, and bull gears on top of that.
