big 12 color
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Topic: big 12 color
    Posted: 21 Jul 2015 at 9:00am
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2015 at 9:02am
i know this is a old topic, but what color and where do i get it  for the allis yellow for my big 12  ?
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2015 at 12:53pm
http://www.wellsimplement.com/bseries.htm Check paint codes here. Lots of variations on colors!
Rod in MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod in MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2015 at 10:19pm
This is what I put on my Big Ten
This is the code of Yellow & Beige on the older ones
HI: This is what the paint shop came up with using there paint gun to match the paint
Nason 676791 IE
car: Chrysler
Code:SY4Year 1979
Color: Brt Yellow
General Motors 649574IE
Beige Cream
Code: 8440
Color: Beige
I used this and it came up as the same as Allis code number
Good Luck
Rod in MN
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2015 at 6:14pm
but i have to use rattle cans,  whose and what color ?  i got yelled at with both that green yellow   and new holland ,what next ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2015 at 7:52pm
some have said old cat yellow   but i can't find it where do i look ?
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2015 at 9:04pm
I was looking at spray paint the other day, at Ace Hardware, sure enough, they have Old Cat Yellow in Rustoleum!
I seem to remember Old Cat Yellow, Cat Highway Yellow, or John Deere Construction Yellow were all matches I've heard of. Rustoleum Canvas White for the white parts.
The mechanic always wins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod in MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2015 at 10:22am
Hi, Some paint stores can mix and put the paint in a Rattle can for you the one I deal with can co that. Most paint stores can do it
Rod in MN
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2015 at 11:59am
You can also get a qt of Nason mixed to the spec you want and purchase a PreVal paint sprayer and spray it yourself just like using a rattle can. That's what I do on my resto Tractors big n' small. Napa has the PreVal sprayer. Comes with a screw-on jar where you put the paint. Neat little bugger! Works great! You can purchase the aresol part separately. The aresol last quite a long time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2015 at 12:26pm
findings    Seymour paints has an old equipment ( cat ) yellow, its 10 to12 bucks a can, it is a darker almost butterscotch yellow.  and hard to find .
Believe it or not  i found Rustoleum  old cat yellow  at Menards  as a farm equipment color.  a little over 5 bucks a can.  again a darker yellow, may come close, assuming the exterior colors have faded, maybe a little darker than the  colors on the inside of the parts, it will be color i end up using.     Unless   there is something else at the GOTO tomorrow!
This page was generated in 0.097 seconds.
