need help sourcing bearings for my 616
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: need help sourcing bearings for my 616
    Posted: 22 Apr 2015 at 2:26pm
Can't get the front axle spindle tube bearings and bushings through Agco.    Anybody have part numbers to go aftermarket
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2015 at 8:32am
Dave,
Might have to press out an old one and have a set made up by a machinist. Bring the spindles with ya and have him mic em' up to get
the correct ID to make the bearing. Had to do that with my WF tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2015 at 9:18am
Which 616?   The 616/620/720 bigger garden tractor or the 616 mower?   In either case, go to Partstree.com, select Simplicity then go look thru pages 7-10 to find the Allis/AGCO models.   Should have what you need.   Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2015 at 9:37am
Big boy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2015 at 9:43am
Same as a Simplicity 4040 PowerMax - right?    Looks like spindle bushing available but not the thrust bearings.   You can take it from here.   Mike
 http://www.partstree.com/parts/simplicity/mowers-lawn-garden-tractor/4040-990705-simplicity-power-max-4040-garden-tractor-16-5hp/frame-and-front-axle/
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2015 at 11:44am
Looks like they have the bushings just need to find the bearings
