616/620/720 mower deck roller dissassembly
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: 616/620/720 mower deck roller dissassembly
    Posted: 12 Apr 2015 at 7:51pm
just wondering how you remove by sets of rollers.
Thanks!
David
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2015 at 8:43pm
Referring to the picture below, remove each shoulder bolt that is above the roller assembly.  Also remove the bolt directly above.  The shaft is welded to the upright on the right side, so you start pulling on that upright to get everything apart.  If you are rebuilding, I'd recommend welding on a new shaft as the original is probably well worn.
Did mine a few years ago.  Had my fab shop make up new uprights as well since mine were worn too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2015 at 9:45pm
I made those over also. Mine were worn too. I made new deck adjusting Tee handles also. Take out all the lost motion as much possible.Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2015 at 5:18am
cool thanks, how about the small roller inside the shell?
ACJohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACJohn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2015 at 8:43am
IIRC, you have to unbolt the brackets for the roller behind the center blade.
