turbo
200 allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Topic: turbo
    Posted: 09 Mar 2015 at 9:21am
Has anyone used Hx 35 hybrid turbo on 301
Ronnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2015 at 9:54am
I am runing a hx35 on my 301 and so far it is working fine for pulling.it is a 190 with home made up pipe to go up the factory hole but if u don't care bout ur hood u just got to move the hole back
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2015 at 9:56am
O I forgot I made the intake pipe to all steal very little rubber
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2015 at 10:23am
I run a hx35 was wondering about the hybrid that useshx40 compressor and hx35 exhaust
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2015 at 10:42am
It would be interesting to see how one works. I am always leery of putting a bigger compressor wheel on any turbo for fear of it being "sneezy", but sometimes it works I guess. You might consider finding a complete HX40 turbo with the 60mm - 7 blade compressor wheel. I think that is the wheel the use for the 35 hybrid. The HX40 turbine wheel and shaft will fit into the 35 bearing housing, but them you have to machine your existing exhaust housing or buy a housing for the 40 wheel.
If you are at 3,000 RPM and your smoke is see through at full load you won't gain much. If it is heavy then you might.
Edited by O.P.S. Heads - 09 Mar 2015 at 10:43am
This page was generated in 0.135 seconds.
