wd flat tops in d17 for pulling
40wc47puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 40wc47puller Quote  Post ReplyReply Direct Link To This Post Topic: wd flat tops in d17 for pulling
    Posted: 26 Jan 2015 at 7:16pm
I was thinking of putting together a d17 enigine with wd flat top pistons worked head and intake. has anyone ran this combo and would 175 cam. specs work well .pulling in wc in 3500-4000 lbs 4-5 mph
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2015 at 10:06pm
175 gov.spring,motec reworked carb,15.5x38 rubber,adjustable pullin hitch=FUN!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 40wc47puller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2015 at 11:43pm
Thanks..I'm sick of finishing second.only pull local pulls and the stock 201 ran strong. problem is a farmall h stripped to get into. 3500 lb class
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2015 at 11:25pm
you will pull the crap out of that H with this set-up,but hey don't take my advice,find out for yourself-my competition did.good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 40wc47puller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2015 at 3:06am
Dad beat him on 47 and all it has is m and w kit but it was close. Our 40 was stick just turned up and it was always just feet from the farmall. I can't wait to pull this year .
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2015 at 6:29pm
i like to beat-up my brother-in -law(on his M that is!)
This page was generated in 0.223 seconds.
