timing
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: timing
    Posted: 04 Aug 2025 at 4:30pm
where do i want to run my timing at 2000 rpm  g226 175 cam big valves big carb high ratio rockers  12.5 :1 compressoin  ,  just got it fired up last night on the fire mark on the flywheel have not started to tune it or put a timing light to it yet
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 6:00pm
A dyno will tell you exactly where the sweet spot is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 6:32pm
no wheel dynos around and no pto ,  will use a vaccumm gauge timing light and a o2 sensor   was just looking for some closer paramiters
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 8:31pm
The flywheel should have had some extra marks added to it to make this easy. The "F" or "FIRE" mark is 30 degrees BTDC on a WC-WD-WD45.  So, it would have been pretty easy to make marks for 15 degrees (half-way between TDC and 30 BTDC) and 20 degrees BTDC. I'd guess you will be 20 to 22 degrees BTDC at full throttle. That's exactly where I would put it even before a Dyno test.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 10:06pm
AND USE AT LEAST 110 octane or better fuel !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2025 at 10:21pm
i got 110 in it  tomorrow i will get it at 22*  at 2000 rpm  and start working from thier
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 6:34am
I'd probably lean towards the 20 degree number to start.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 9:48pm
thanks Dr. put the light on it was dead on the fire mark,   the throttle response was pretty dead , put it on 20 and picked up 100 rpms put it at 2100  and give it some good throttle response made it snappy , so know   i am on my way to fine tuning still havent moved it under its own power yet
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 7:53am
What you absolutely don't want it ANY kind of detonation under load. I don't know which carb you are using, but if it's a G-226/W-226 Marvel Schebler, I'd drill out the removeable main jet inside the bottom of the bowl .002" or maybe .003" to give your carb more fuel delivery. As it is, your adjustable "L" external main jet will be screwed out several turns which then is maxxed out by the jet size in the bowl. This is sized for 226 cubes at 7 to 1 compression, so a little more fuel flow would be prudent. I've always used colder AC Delco 42 or 43 spark plugs, not 45.
Edited by DrAllis - 06 Aug 2025 at 7:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 8:10am
new zenith for a d 19
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 10:46pm
This page was generated in 0.111 seconds.
