Tillage Question
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Topic: Tillage Question
    Posted: 27 Sep 2026 at 7:05am
Not color specific.
What tool have you guys had luck with for tall and or thick sod?
My big moldboard plow does ok, but there are fields where it’s not too handy. And honestly…..it could be better.
Glencoe soil saver is a no-go, it’s plugging.
My most recent small plow is an IH 400. That plow does a wonderful job and pulls easily…right up until it doesn’t, then it’s miserable. In heavy sod, it rides up and gets caught on the shank and from there is all downhill. It seems to me the colters are too big and too close to the moldboard, and also not much clearance under the frame. You get to a point where you’re only 3 inches deep, then to a point where it still scoops up grass and it’s all plugged up.
Just curious if anyone has good luck in such a case.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2026 at 7:26am
As for the grass/sod/trash on the surface, try disking the field first. Or, mowing, baling a crop off the land first. As for coulter and plow adjustments, get an owners manual for that specific plow. Does the the plow have ‘coverboards’? Some call them ‘trash boards’. Proper ground speed can also affect the performance of a moldboard plow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2026 at 7:50am
I've never done this, or for that matter even seen it done, but in the old days, they would tie a length of #9 wire on a coulter or somewhere on the frame, and that dragging wire would fold over the tall brush so it didn't plug.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2026 at 9:09am
There are two locations to mount the colters. Already in the farthest forward, won’t even fit in the rearward one. Makes me wonder if it’s the correct colters.
I’m doing the mowing and baling. Would sure love to skip that and save the time and fuel.
Nothing to do with coverboards, it doesn’t get that far and if it does it turns over fine.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2026 at 9:19am
My friend used to have a pair of IH #720 plows; 5-16' & 6-16".  They would only plug in very heavy (and/or damp) cornstalks.  Sod plowing was a breeze.  FWIW.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2026 at 10:44am
The later years AC 2000 plows had 32” of clearance. And if it was setup with high speed 392 moldboards, then even better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2026 at 11:49am
I am so glad you made this comment! That is very specifically one of the things I wondered. Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2026 at 11:51am
I used to have one, it pulled great, and as I recall I turned over a lot of sod with it. I remember it doing very well. We had trouble sourcing wear parts for it is why we parked it. Since sold it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2026 at 12:42pm
I've seen a properly set plow go through weeds taller than the top of a tractors muffler without plugging. Coulters + jointers and weed hooks
  Find a set of concave coulters for your plow, anyone can make any plow go through anything without plugging with them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2026 at 3:43pm
Dad had a#9 wire tied on the 2 bottom 52. Just the front bottom but it also had them coulters which had a small concave coulter paired with it. Can't remember the brand name.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2026 at 1:47am
How/ where is this wire tied?
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2026 at 7:14am
Lance coulters?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2026 at 7:17am
I think it gets tied to the rolling coulter shank and is routed to the inside of the coulter blade so it gets drug towards the moldboard. It folds over the brush pretty flat so it doesn't plug the throat between the bottoms. It would extend at least as long as the moldboard and maybe a little beyond. Say what you want, but I'm sure this was a well-known trick 60 and 70 years ago with 12 and 14 inch plow bottoms and not much throat opening on ANY plow of that day.
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2026 at 7:39am
Yes for the #9 wire solution! As a kid, I remember Dad using this for sod, cornstalks, or whatever needed. Also, yes for anchoring wire to Coulter standard and letting it trail past end of moldboard. Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2026 at 8:05am
Interesting. Still not sure I’m visualizing correctly. A loop, or just a straight wire dragging? Only tied on one end? If I get a chance in the next couple days I’ll put one on and take a picture and see if I’m on the right track. Thanks for the discussion guys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2026 at 9:32am
yes, i would like to see a picture or a drawing of that... I dont understand what dragging a wire does ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2026 at 9:50am
I’ve been thinking heavily, smoke starting to roll out of my ears.
The visual I’m getting is if you picture direction of travel, tie the wire to the colter shank and rout it to the left of the colter. Then bend it about 90 degrees or maybe a little less and route in front of the moldboard, the whole width of the moldboard. That way you would be folding over the grass in front of the moldboard as you travel. I think. Hard to imagine it’s stiff enough but must work since several have mentioned it.
Edited by Tbone95 - 28 Sep 2026 at 9:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2026 at 11:24am
As i remember the wire was as long as tip of mold board and bent to follow contour of mold board. It just flopped loose. The dirt being turned kinda buried the trailing end which held it in place to force grass etc to lay down and get covered. The wire was not tightly tied around coulter shank. Just looped. and tied back on itself. That was 50 yrs ago so may not be 100% correct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2026 at 11:45am
Secured at the coulter shank end, yes. But make sure you get it wrapped so it doesn't pull apart as there will be a pretty good tug on that wire tucking and bending over the tall stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2026 at 12:36pm
Well, with any luck and a spare half day, I’ve got an acre spot in a field that I’ve had to stay out of the last two years because it’s wet, I will be giving it a try.
Thanks again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2026 at 1:11pm
I didn't clarify... a single strand of #9 wire is being drug along.
Mo farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mo farmer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2026 at 1:48pm
https://talk.newagtalk.com/forums/thread-view.asp?tid=543996&DisplayType=flat
Look at this. This is the way grandpa would rig #9 wire to cover tall grass.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2026 at 1:58pm
Hey mofarmer, thanks! I get it. I was over complicating things in my head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2026 at 2:06pm
well dragging it down the bottom of the furrow and burying it on the back makes sense now,... I pictured it running side to side and didnt see how that was going to do anything !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2026 at 2:38pm
As low as possible on the front looks best to me.
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2026 at 8:03pm
Mo Farmer, that's it.  Dad had bottom land that flooded out with no crop planted.  About this time of year or a little later it got plowed under.  Sunflowers, etc. taller than the tractor got rolled under pretty good with the wire.  I don't remember for sure, but the wire was 4-6 ft. long and would wear off after heavy use.  Never used it on short stuff, alfalfa or brome sod.
