Strange wd45 at auction
wide View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wide Quote  Post ReplyReply Direct Link To This Post Topic: Strange wd45 at auction
    Posted: 21 Mar 2019 at 1:03am
Tall boy at an auction in Nebraska:
https://www.auctiontime.com/listings/farm-equipment/auctions/online/31565751/allis-chalmers-wd45
 Not sure that looks safe, ha.
 How much will it go for?
 Also a not so strange D14.
https://www.auctiontime.com/listings/farm-equipment/auctions/online/31380819/allis-chalmers-d14
Wonder what that will go for.
 Also one near me with a D17III with a bad engine and good engine included.
https://steffesgroup.com/Auction/AuctionDetails?Name=exclusive-multi-party-farm-retirement-auction-31865
It'll be this weekend. Wondering what a non-running D17 will go for,
guess I'll have to go see.
Edited by wide - 21 Mar 2019 at 1:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 1:10am
lol...I agree! I've seen others built up the same way, a different Allis, a 8N ferd, an Oliver. I think it was a kit that you could buy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 1:12am
I just remembered...Hagie high boy sprayers started out with tractors like this, same type drive, then they changed over to their own hoods.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 7:57am
According to the number, the engine is WD.
But...... it has the curved shifter.
The engine serial number puts it right at the beginning of the transition to the
helical-cut tranny (curved shifter) so I would say its a late WD.
Edited by Brian G. NY - 21 Mar 2019 at 8:11am
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 8:04am
Interesting!
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 8:46am
I like it but it would probably turn over in my drive way.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 8:52am
D17 engines go for quite a bit, but I'm thinking someone had a bad engine, bought another engine to transplant, and found out it was bad as well.  Maybe $1000 and part it out.  I think those weights, and other parts may be worth that, plus!
savedallis1953 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote savedallis1953 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 8:58am
Has to be fun to crank start.
1953 WD, 1953 WD, WD engine with WD-45 crankshaft.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 7:58pm
Imagine how tall it would be if all four tires had air....! HA
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 8:20pm
What would that be used for. Is something like that done at dealer or factory
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 8:41pm
Can't imagine hauling it on a trailer with that high of center of gravity.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 9:49pm
Those were used in hybred seed corn production. Uncle Frank had a tractor salvage lot. One of our local seed producers took 20 8n ferds, bought conversion kits like those and attempted to spray and to other things around the seed corn acres. They didn't have enough power to do the job. On top of that they were too unreliable when it came to starting. Uncle Frank bought all of them, removed the conversions, put them back to 8n ferds and shipped them all out of state. I was there and helped put them back to the original form. The seed corn company bought up some D17 allis and had them converted.
wide View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wide Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 10:14pm
 Great parade tractor.Big smile
wide View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wide Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2019 at 9:53pm
I took a look at the D17III today.
 I was thinking the engine was bad so they found a good engine but never got around to putting it in.
 But it looks like John was probably right,
 they didn't install the engine because it's broke too.
 There is an engine on the ground next to it,
 I couldn't get it to turn by hand, on the crank pully.
 Wouldn't budge. Should be able to turn it by hand right?
 Or should I have gotten the breaker bar out?
 Got a chance to talk to an old guy about it,
seems he'd been looking at it.
 He pointed out the lever and told me to shift it forward.
 It popped right back up.
 Supposed to be a 2-speed gearbox but it won't stay pushed forward.
It was nice to get a close up look at a D17III. I might go back this week and sit in the seat like a kid,... push some peddles.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2019 at 10:02pm
So the Power Director is bad. If the block and the crank on the second engine are good you can rebuild it. That tractor can be fixed, but be prepared to shell out some $$. If you can't do the work yourself don't even think of going there.
wide View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wide Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2019 at 1:50pm
So that's what they call the power director,
 that lever to the right of the driver runs it and it chooses between a high and low gear. Like a 2-speed rear end in a truck.
I'm sure I could figure it out mechanically, especially with help from people on this forum.
 But I'm still set on getting a WD to work on,.. I think I found one just waiting for the ground to get solid again,.. and not the froze kind of solid.
wide View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wide Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 5:08pm
wide View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wide Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2019 at 4:11pm
That tall tractor sold for over $3000
