Spin out rims
Stoges View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stoges Quote  Post ReplyReply Direct Link To This Post Topic: Spin out rims
    Posted: 29 Jun 2025 at 7:30am
I have a WD with spin out rims, how do I keep them from spinning out during a pull, I tighten them with a heavy duty impact. I really don’t want to weld them.  Thanks Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2025 at 10:05am
Do you see the small holes in one rail? There is supposed to be a stop block on either side of the PAW block.
AintCheatnAintTryn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AintCheatnAintTryn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 5:44pm
what paulB said, there are holes on the square slides on the rims, steiner tractor sells the stops for 17 bucks, i believe what you need is part number mis109, youll need the bolts (mis110) for em too which are 9 bucks. you can probably get a few off someone here or at flea markets for cheaper. if your loading your wheels with weights, watch tightening your locks with am impact, you dont wanna snap them off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 6:20pm
The lock eccentrics on a WD only rotate about 180 to 200 degrees !! You can hammer all you want but they won't get any tighter !!!   Get the MISSING rail stop blocks.
This page was generated in 0.081 seconds.
