Smallest silo?
500592 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 500592 Quote  Post ReplyReply Direct Link To This Post Topic: Smallest silo?
    Posted: 06 Oct 2026 at 5:41pm
What’s the smallest silo someone has ever heard of? I’ve been day dreaming of getting a couple of beef cows. What’s the smallest silo someone has seen? Would it be possible to build an old fashion wood silo say 4’ or even 8’ in diameter and about 16’ tall to feed a bit of chopped grass or corn in the winter months? No much ag around here anymore so it would be hard to buy small amounts of silage for just a couple cows and it would be nice to chop the first crop early when it’s hard to make dry hay. I’ve got a sawmill and well equipped wood shop so making the staves wouldn’t be too hard. Any chance of this working or would it just be a large compost bin?
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2026 at 7:26pm
I fill a 12 by 40 silo that has a surface drive uploader. I fill it in October and its gone by june. Remember if you fill an upright silo you are going to have a couple of inches of spoilage on the walls. You also need a certain height to create enough force to eliminate any oxygen. I would think a wooden structure may be your best bet. Having said that, you are trying something different make sure you get it tested before you feed it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2026 at 7:28pm
It can be done, but sealing a wooden silo and keeping it sealed would be the hard part...Wink
I just remembered a story in farm show magazine, the title for the article is "silo trailer attracts attention".  It's about a salesman's model of a Unadilla silo, 10 or 12' tall mounted to a trailer... The story has the guy's name and number or address in it (New York), as most do, in Farm show magazine, and you can search the archives for free, I believe, without being a subscriber...  You may also want to search for Unadilla silo.
The whole trick to efficient silage is to remove enough each day, to keep spoilage to a minimum.  This means knowing how much your hypothetical cows are going to eat, and sizing the silo, both in diameter and in height...  There are formulas for all of this that I can't remember, but was taught back in college, in 1985...Confused
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2026 at 8:04pm
Unadilla still exists. They make trusses now, but they did get out the ols tools to build a small silo for Delaware county fairgrounds
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2026 at 8:40pm
Ever hear of a silage "bag"  ?? that lays on the ground and gets sealed up when full ??
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2026 at 9:32pm
We have a 10x30 cement stave silo still standing. Last time we filled it in the 1980s it only took a short afternoon. I think the other silo grandpa had was a 12x30. That one got replaced by a 16x60. Wood stave silos were in the 10x30 range. They were made from high quality cedar. Some of those board outlasted the actual silos. Just make a ground pile on plastic and pack it and cover with plastic. We have a farmer we open fields for, when I help a silage crew in fall. We dump 2 to 4, 24 ft silage wagons for him depending on what fields he wants opened. That's what he does. Or you can do it between rows of round or big square bales with plastic.
Edited by DanWi - 06 Oct 2026 at 9:33pm
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2026 at 9:34pm
If you are only raising a few head of cattle, I wouldn’t even mess around with silage. Baled hay, and ear corn. Grind your own, is the route I would pursue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2026 at 5:32am
Here the typical Is a Silage ‘bag’ or bale wrapped fermenting sleeve of silage they start at one end and feed until is gone. Or as with our Renter a Trench Silo, one aite they use is an old barn footered Concrete Floor fill and mound then cover with old billboard Ad tarps.
Edited by DMiller - 07 Oct 2026 at 5:33am
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2026 at 5:42am
An old farmer near me who immigrated to Canada from Holland told me that when they first came out with square balers, farmers in Holland would lay plastic sheets on the ground and stack green (not dry) square bales on the plastic.
When the stack was the size they wanted, they would wrap the plastic around the bales and secure it (maybe use tape?) so no air could get in.
When they needed to feed it, they would then open one of the stacks and feed the ensiled hay out. I suppose they would reclose the unused stack until it was gone.
Edited by WF owner - 07 Oct 2026 at 5:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 500592 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2026 at 8:48am
These are probably real dumb questions to a normal farmer but I assumed a narrow silo may help with feeding enough off the face to keep it spoiling and wouldn’t require a bag filler or a large area that a covered pile would need. I also thought that the silo would be a nice looking building 🤣
Maybe a I could rig a small silo bag like a trash bag inside the silo to help prevent spoilage? I several people experimenting with silage in plastic 55 gallon drums but having a whole bunch of those laying around seems like a bit of a pain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2026 at 10:34am
I remember (when I was a kid looonnnnggg ago) they used "silo paper" inside wood silos to prevent spoilage. I don't remember there be any spoilage around the sides. I believe the stuff they used was almost a tar paper that had some sort of tar coating. It was about 4' wide and pretty stiff.
I would assume plastic would work, but it might be tough to get it to stand up while filling the silo. Maybe the top could be stapled to the walls and the staples covered by the next higher row of plastic?
I don't know if the moisture in the silage would make the wood staves "swell" enough to seal up cracks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 500592 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2026 at 11:37am
I did read that people used roofing tar paper to cover the doors.
I found some smaller diameter bags / bale tubes that could be cut down to size and draped in just like a trash bag. As I fork the silage out the extra plastic could just be trimmed or possibly folded for reuse but is fairly inexpensive. Probably a lot more work to feed out of but I’m okay with it being more of a novelty. Plan b for the silo would be storing wood shavings.
Dirt Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2026 at 12:51pm
Instead if plastic barrels how about cleaned out chemical totes with the lids cut off then duct tape back on to seal. The plan B for a silo would have me nervous about wood shavings and sawdust and a chance for spontaneous combustion. If you want a neat addition to your homestead I’d look for an old wire corn crib and raise peacocks in it. That won’t help the cows but it would let you know when someone pulls in the driveway. Just a thought
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2026 at 6:06pm
Pit silo is a cheaper? Better? option. If your farm has some topography(hills/embankments/ etc) then you could potentially excavate a 5-10’ deep x 20’ wide x 40-50’ length inclined (10* slope?) trench thru a hill to build a pit silo.
Chopped / filled corn silage wagons & tractor then drive thru the pit silo where the wagons unload their silage content. Another dualled tractor equipped with a rear blade or front loader spreads/levels silage while packing in down (pushing out air) with its weight via its tires. Repeat fill/level pack, repeat, repeat etc, til top of pit silo has a 2-3’ tall in middle arched top surface that helps shed precipitation.
Fermenting silage will Oose liquid which will flow down floor incline & exit on lower end. Top 4-6” will spoil but will seal rest of silo & is usually discarded as needed. Leave spoiled roof as a seal. Work (load out) from lower end working up incline. Like others say, pitch fork a needed vertical layer as needed EACH DAY to feed it. When freezing temps happen, this process usually only produces about 2” of frozen silage on load out face per each feeding per day. And that frozen silage will thaw when mixed with warmer ground insulated silage. An inexpensive DIY rear wooden bunk(1-2cu yds) or an old split fuel oil tank laid horizontal can be mounted to tractors 3 pt works great to hand fill & hand feed out onto froze ground or fence line feed bulk? In muddy conditions, the rear weigh of filled silage bunk assist tractors rear tires to traverse muddy ruts etc. So inexpensive, simple, & it works. Great cardio exercise for farmer feeding every day too.
Edited by AC7060IL - 07 Oct 2026 at 6:13pm
dp7000 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote dp7000 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2026 at 6:13pm
We made corn silage right on top of the ground. Dump wagons on top of one another. Dump an area of 30ft x 50 or larger. Run a tractor over to compress as you go. Probably ours was 4-5ft high. Slope in all directions for water to run off. Dig a little trench along the sides and ends, cover with plastic and cover plastic edges with dirt… sides and ends. We would put some used tires on top so wind wouldn’t pull plastic off. Worked great, did it for years. Just make sure you have silage packed tight and plastic sealed. Ensiled in a few weeks. Only place it would mold is when a little air got to it. Mold was rare, and we would cull any that molded. Very little waste.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2026 at 7:23pm
I vaguely remember someone made plastic liners for wooden silos. Talk about the end of an era, upright silos
Michagman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michagman Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2026 at 9:28pm
How about standing a steel culvert on end?  It could then be dressed up with wood that isn't necessarily air tight.  You could even sandwich some insulation in between.
I would just add that it probably should be either very narrow, or wide enough for you to swing a pitchfork while standing inside of it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2026 at 9:37pm
So are you literally talking 2 cows? I think it would take 15 to 20 to make silage worthwhile. I have ten plus 5 calves from this year. They have some pasture to nibble on and eat 1 Big square bale every 2 1/2 days.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2026 at 7:19pm
I don't know, sounds like it could be a fun project. Unadilla always said" the proof is in the wood" there is a you tube video of them building a mini silo for the Delaware county fairgrounds
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2026 at 9:14pm
If you know what you're looking for in my area, there are quite a few of those trenches along the edges of pastures or where a valley bottom meets the pasture/slope. They must have been very common back in the day. Probably only the rich guys had silos here LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote 500592 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2026 at 4:43am
Is there a reason silage isn’t a great idea for just a couple cows? I thought it would be good way to harvest some early grass when the weather isn’t great for dry hay and areas I can’t fence for pasture. I don’t think it would too hard to find a chopper and blower. I have seen those for sale occasionally.
The culvert idea is intriguing. I hadn’t thought of that. A plastic one would really keep the air out.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2026 at 5:03am
They give away pull type choppers here and yes, try to make dry first( or 4th cutting) can be really difficult.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2026 at 6:03am
I always thought that heavy duty large garbage bags could be filled with chopped hay or corn, packed, sealed and fed as individual servings. Maybe a short piece of plastic smooth bore culvert could be used to hold the bags during filling and slipped off after sealing. It would be pretty labor intensive but might be worth a try.
Edited by WF owner - 09 Oct 2026 at 6:04am
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote dp7000 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2026 at 6:20pm
I read once upon a time in Progressive Farmer about using plastic, pvc pipe and a shop vacuum.
You lay one layer of plastic down. Place your material on top and cover with another layer of plastic. Then you roll sides and ends of plastic around 2-3 inch pvc pipe cut to exact length a couple of times. You then secure plastic around pipe with a larger size pipe cut into 4 inch lengths cut into a C shape clipped over pvc every 3 ft or so. Then in one corner use shop vacuum to remove all the air and seal up for it to make silage.
I believe this was done for high moisture round bales but should work for a pile or windrow?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 500592 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2026 at 5:09am
In my continued research of small scale silage I ran across this rig. https://m.youtube.com/watch?v=g8k9J9EqlWc&ra=m
I don’t think I would want to find out how long it would take to run an acre of grass through it but I may try a filling few heavy duty trash bags and sucking the air out with a shop vac.
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2026 at 5:09am
If grass is all your cutting,why not consider a silage round baler and wrap the hay? My association with alfalfa silage in a tower silo is it packs really hard and is difficult to get out. And the acids in the haylage destroy mechanical equipment used to empty the silo. We went to Ag Bags for that reason. We're I feeding grass silage today I would make it with a round baler and wrapper. My Dad always said that's why the Good Lord put Teeth in Cows!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2026 at 8:49am
get the 95 gallon bags... fill and use the vacuum to pull out the air... cheap and easy.. this is Wal Mart... little over $1. a bag.
Edited by steve(ill) - 10 Oct 2026 at 8:53am
This page was generated in 0.116 seconds.
