Second new Starter Failed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Second new Starter Failed.
    Posted: 30 Jun 2026 at 7:14am
Went to start my 180 to drag out and finish as laid fresh rock on drive, Failed.  Hammers into Flywheel HARD, Ammeter buries Hard Over and no rotation, Reached in rotated engine by hand at Fan, NOT locked up, was no indications when last parked as a problem.  Going to pull it off today and see if can rotate starter by hand.  May have a failed Field winding and a Magnetically Locked Armature.
Not very happy with the heat here but at least is inside the Shop not down at barn.  Had moved it for Vacation Trip only three+ weeks ago started just fine.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2026 at 7:41am
I have encountered a different problem so i understand your frustration
All the 426 engines ive had have had nippendenso starters. I thought they were great starters. Ive had two tractors i acquired with some fuel system problems
In trying to get them started and ehe engine didnt start on that attempt the starter wouldnt stop. Then its scramble to get the batterys unhooked so it doesnt set the thing in fire
Unexplainable
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2026 at 10:17am
Been out in the shop and tried Direct bypass of Start Circuit with a Remote Button Switch, Starts Fine, started Digging, FREAKING Rodents.  Found some wiring chewed, working at that, then noted terminals loose on Clutch Switch, that has been ordered, possibly Low Volting Start Side pull in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2026 at 6:07pm
Bypassed old Switch, been starting fine, new switch be here tomorrow.  Got Drive raked and smoothed, Shut it off several times, all back to a Normal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2026 at 6:37pm
Gr8
1984 80780
1957 D14
616 tractor
