s300g
Bob C IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Topic: s300g
    Posted: 25 Sep 2012 at 6:50pm
Puttin a 5.9 cummins in the ole 7000, lookin for a s300 gated turbo 57mm inducer. Any help appriciated....
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 7:12pm
How many HP are ya lookin for? A s300 in a 57mm is no better then a good old hx35. If I was you id go with a holset he351. 60mm inducer,58mm exducer on the exhaust with a 9cm wastegated housing. They are good to about 400-4500 HP on the 5.9.    It will spool fast and cool very nice. Thats what I run on my 301 in my 185.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 7:17pm
Rules limit me to a 2.3 inducer and HX35 does not have the shaft for 50 to 60 psi boost! S300 is better built, but I am open to suggestions.... Need 450 Hp at 3000 rpm limit..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 7:24pm
Ok that sure puts a damper on that.   Well ur best bet would be to call a turbo builder and pick there brain. Glenn or Chris at Engineered Diesel make a very nice charger.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 7:54pm
Where abouts are they located and you got a number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 8:04pm
http://www.engineereddiesel.com/     they are in Michigan. There numbers are on the top. Chris can be a ass if he wants to but Glenn is a good .   Just tell him what ur doin and they can set ya up a nice s300 with a billet wheel too.
Also what are ya doin with the motor besides bigger pump and injectors? Doin a cam, valve springs,pushrods, port and polish? What pump are ya using?? If ya need help I can put u in touch with a great pump guy and injector guy.
