Rt angle gearbox |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9238 |
Topic: Rt angle gearboxPosted: 30 Aug 2024 at 6:52pm |
Old 7016 Simplicity. What is procedure to get cross shaft out? Down to bare shafts sticking out and don't know how to get snapring out of gear.
Joined: 11 Sep 2009 Location: illinois Points: 93360 |
Posted: 30 Aug 2024 at 7:52pm |
assembly starts at 14:50.
Steve... am i looking at the wrong thing ? I dont see a snap ring.. https://www.youtube.com/watch?v=ZLkO4f5CePc Edited by steve(ill) - 30 Aug 2024 at 8:00pm |
Posted: 30 Aug 2024 at 8:00pm |
Codger
Posted: 31 Aug 2024 at 6:21am |
Don't know if a hydrostat, or gear drive but here is a breakdown: |
That's All Folks!
Mikez
Posted: 31 Aug 2024 at 7:30am |
What are you trying to do to bevel gear box
SteveM C/IL
Posted: 31 Aug 2024 at 9:35am |
That shaft he slipped in is larger dia where it shoulders gear. Mine has a wire ring. Looks like just drive shaft out of gear. I have a broken tooth gear box in running tractor and "good" gear box in parts tractor. The good box has a bad keyway on through shaft. The bad box has good through shaft. I thought I 'd just switch shafts but don't know the procedure
SteveM C/IL
Posted: 31 Aug 2024 at 1:45pm |
...shaft just drives out of gear.....
Edited by SteveM C/IL - 31 Aug 2024 at 1:46pm |
Mikez
Posted: 31 Aug 2024 at 8:32pm |
The ring is a pain in but you just work it out with a pick. Usually gets bent and should be replaced. And should not have to drive gear. The ring is what holds it. There was different shafts. Depends on whether it was a gear shift or hydro or variable speed.
