power director |
200 allis
Joined: 11 Mar 2014 Location: new jersey Points: 203 |
Topic: power directorPosted: 04 May 2016 at 7:17pm |
Does anyone have a diagram on how to delete power director and still use hi and low
Dans 7080
Posted: 04 May 2016 at 8:03pm |
The power director is the high and low.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
200 allis
Posted: 04 May 2016 at 8:18pm |
I want to make it mechanical shift
bsallis180
Joined: 29 Jul 2013 Location: Pennsylvania Points: 209 |
Posted: 05 May 2016 at 8:45pm |
If you eliminate the hydraulic power director. Then you have to replace it with the coupler to lock the shafts together Or a small gearbox but you have to stop and change gears.
200 allis
Posted: 06 May 2016 at 6:54am |
I looking for a coupler would prefer hi and lo but low would be good for now
bsallis180
Posted: 06 May 2016 at 7:06am |
Need to get a hold of Mac on her he has them
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5276 |
Posted: 06 May 2016 at 9:19am |
I think DR Allis, or OPS heads has what you need. How much power were you still getting away with using the PD still?
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3812 |
Posted: 06 May 2016 at 9:21am |
Mack sells mechanical boxes for 190
found it here is what Mack is selling ![]() Edited by CAL(KS) - 06 May 2016 at 9:30am |
O.P.S. Heads
Posted: 06 May 2016 at 12:21pm |
If you want the use of both the high and low range but do not want the issues of a potential P.D. clutch failure or slippage contact Dr. Allis. This is not an on the go shift, but you can choose either high or low range. Mack's gearbox eliminates low range but either speeds up or slows down the remaining 4 gears. Just depends on what you want to do.
200 allis
Posted: 06 May 2016 at 6:12pm |
I want to eliminate powe director so I don't have problems down road I would like to use hi and lo to keep my options open but right now just running 7th gear.
MACK
Posted: 29 May 2016 at 10:31pm |
It is wise to get rid of PD clutch. With RPMs it is a bomb waiting to expand. MACK
