Plowing
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Topic: Plowing
    Posted: 26 Oct 2026 at 5:48pm
Tried plowing again today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2026 at 5:57pm
Did close to one acre. Tough going. Rough field that hasn’t been touched for 30 years! Very dry here. Has not rained for a month or so here except for couple brief showers. And the plow is not in real good shape. Would not dig in. Got the manual out (lucky I had one) and made some adjustments. Made it a lot better - got down 4” to 6”. Low gear seemed to work best. Pulled great in 2nd but ground was too rough!
IBWD MIke View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2026 at 5:05am
Ed, you're a little far away or I'd come up and help. Looks like you're getting it done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2026 at 7:11am
I have a video as well but my iPad will not post it. Says it cannot do img format. May have to update computer. Lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2026 at 5:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2026 at 5:07pm
Plow is 3-12’s.  Going to shine up the mouldboards a bit!
Edited by Ed (Ont) - 27 Oct 2026 at 5:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2026 at 5:22am
It will pull a lot easier once it scours. 12" bottoms are kind of unusual, I've never seen any in this part of the world.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2026 at 9:51am
They were common up here. Lots of rocks where I grew up.  I have a 2-14 snap coupler as well. Should try it as well. 😀
Edited by Ed (Ont) - 29 Oct 2026 at 1:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2026 at 10:28am
Was reading the post on brush hogging and noticed comments on removing pto shaft for plowing. I had not done that but will next time! I did go out and check clearance and had some about 2" of clearance there. I guess if you hit rock or stump could do damage then. Rechecked manual and it tells you to remove pto shaft! Lol. Smile
19F150 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 19F150 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2026 at 4:12pm
I have SC 2 bottom 12inch plow
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2026 at 6:56pm
Around here, all the plows I remember from back in the 60's were 10"-12" or 12"-14".
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2026 at 9:03pm
Thanks for sharing pictures. I have also noticed that the width of bottoms varied in different parts of the country... Mostly 14s and 16s anywhere in the handful of places I have lived in the Midwest.
I don't feel like dropping the PTO shaft is too bad of a job as long as your cross bolt isn't all bent up, and if it is, it should probably be replaced!
