Nylon Bushings |
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3276 |
Topic: Nylon BushingsPosted: 16 Sep 2026 at 7:08am |
Does anyone know a good source of nylon bushings or bushings made from a similar material? Specifically I need a bushing with a 1 1/4 inch outside diameter and a 7/8 inside diameter.
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 5032 |
Posted: 16 Sep 2026 at 7:24am |
McMaster-Carr has several types in that size
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 56158 |
Posted: 16 Sep 2026 at 3:27pm |
If you have a wood lathe, you can turn them from just about any nylon stock. I needed some bearings for the castor wheel on the front of my zero-turn mower, had some 1 X 6 black nylon boards I picked up from craig's list real cheap, so as a temporary measure, I turned some 1/2" ID X 1-1/2 OD bushings with a skew chisel, real quick on a Sunday mornin, and them things are still on the mower. Once the nylon gets loose and sloppy I'll put the right parts into it, but I'm cheap, and can wait...
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6167 |
Posted: 17 Sep 2026 at 11:13pm |
I got tired of looking for just the right plastic bushings, and making bushings from plastic on my lathe... I bought a 3D printer, loaded it with PET-G filament, and never looked back... 1 1/4 inch outside diameter and a 7/8 inside diameter... HOW LONG? I can draw that bushing in 4 minutes, and print it in probably 10. PM me your address, and tell me length, and how many you need! DK :-)
Edited by DaveKamp - 17 Sep 2026 at 11:14pm |
DaveKamp
Posted: 18 Sep 2026 at 12:00am |
Correction... I drew it in 3... and going full solid (100% infill) it takes 18 minutes, plus the 4 minutes it does for self-test/calibration before a run... this one is only an inch long, but it's running now. I drew these to exact dimension... the printer nozzle is usually pretty accurate, but when going full-solid sometimes the IDs are a smidgen tight, and the ODs are a smidgen fat... so if either are really critical (meaning, it won't work with any variation), then either it gets hand-dressed to size (sandpaper on a dowel) or I make a little adjustment to the drawing to compensate, and re-run it. |
DaveKamp
Posted: 18 Sep 2026 at 12:13am |
DaveKamp
Posted: 18 Sep 2026 at 12:17am |
DaveKamp
Posted: 21 Sep 2026 at 10:04pm |
Gary- check your PMs... should be in your mailbox around Saturday or so.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4260 |
Posted: 21 Sep 2026 at 10:19pm |
thats very cool
