‘Nother Water Question
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Topic: ‘Nother Water Question
    Posted: 5 hours 13 minutes ago at 7:07pm
Soooo… it’s recommended that the air pressure in the bladder tank be set 2-3 psi lower than cut on pressure.
Water at dad’s was acting up. Biggest problem turned out to be the sense line to the switch was plugged. Anyway for thoroughness I replaced the pressure switch. Guess I bought a lower pressure setting. I bought a 30-50. When the switch kicks on bladder tank pressure is about 35.
It seems to be working fine and cycling normally with a steady flow of water. So, ??? Should I put a 40-60 on it? It doesn’t seem to be broke so I tend to not wanna fix it!    Got plenty of other things to do.
