Need help in Mason Mi
Ewhitford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ewhitford Quote  Post ReplyReply Direct Link To This Post Topic: Need help in Mason Mi
    Posted: 07 Apr 2019 at 3:33pm
Okay folks here's my problem and I really would like someone to come out and show me what in the heck I goofed up on. Here's the issue. I looked at my owners manual for my 1950 WD on how to adjust the clutch and evidently I screwed up something. I was trying to adjust the pedal and rod for the clutch as it seemed to me anyway that when I pushed the clutch in it would not fully disengage the transmission. Went out of gear great but the only way to put it into gear without grinding them was to shut it down. It always worked fine but over time it started to become harder to put it in gear. So out came the manual and looked up the problem and thought I did what it said. Well now it goes into gear just fine but it will not move. The clutch pedal is now set up for a person that stands 8 foot tall. I can't correct that for some reason and the clutch pedal will not return to the engaged position completely. So there you have it my goofed up mess. Normally I can do these things but since my health issues it seems I am not as good as I used to be or thought. So if someone would be so kind to help me out as she's my go to tractor around my small hobby farm. Thank you greatly.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2019 at 6:23pm
Has the throw out carrier been greased. Sounds like it is stuck in disengaged position.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2019 at 6:59pm
Almost sounds like a collapsed pressure plate, or a stuck PP. Sometimes if you over adjust them you push them over center which sticks the PP.
Steve@B&B
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2019 at 7:40am
I'm out of Charlotte near Potterville.
I grew up on a '53 WD. Never worked on the clutch.
Dusty
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2019 at 1:16pm
You might check with Williams Equipment in Charlotte. Been a dealer for a long time.
