Model D Grader Starter
Allis Grader Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Grader Guy Quote  Post ReplyReply Direct Link To This Post Topic: Model D Grader Starter
    Posted: 09 Jun 2026 at 12:36pm
I have a Model D grader with a WD engine. The starter will occasionally make just a click sound when I push it. When I tap the starter with a hammer it works fine. Steiner has parts for it: Model #: 1107962.
They have: Starter Drive (Bendix), Starter Drive Assembly that includes the Armature, Starter Drive Spring only, and the Starter Brush and Bushing kit.
Anyone know which it most likely needs, or should I go with the Starter Drive Assembly Kit and Brush & Bushing Kit to get everything covered?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2026 at 3:16pm
First thing I'd do would be to examine the solenoid.  Look for bad connections and corrosion...Wink
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2026 at 12:34pm
If it does nothing unless tapped - i would say brushes are not making good contact - Evidently the solonoid is not mounted on starter like a car type starter where solonoind pulls in starter drive
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Grader Guy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2026 at 5:22pm
That is correct, the solenoid is not mounted on the starter. When down there the next time I will pull the starter and perform the steps that have been suggested, especially replace the brushes. Thanks to you all.
