Lumbar fusion
1951WDNWWI View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1951WDNWWI Quote  Post ReplyReply Direct Link To This Post Topic: Lumbar fusion
    Posted: 19 Feb 2026 at 7:12pm
Had to have L3, L4, L5 fusion.  Every thing is progressing nicely in the recovery.  Have been told the WD will require too much bending with the hand clutch, position of the seat, etc... What has anyone else experienced?
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2026 at 8:15pm
I had a Luminectomy Oct 20 on all  L1 to L5 .  I had a routine check up this morning and was encouaged to continue physical therapy and do what activity I can tolerate.  I intend to operate my D-12, D-15 and D-17 this spring.  My concern for the 45 would  be swinging your right leg over the drive housing then not being able to put some weight on your foot as it lies forward putting all your weight on your butt. lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2026 at 8:29pm
very happy to hear you're doing 'very well' !!!
I have 'paper thin' discs between L3-L4-L5, found that out  at new chiropractor one day. saw an X-ray in the room, compared it to the 'chart', when doc came in , I said ,'gee that guy must be in pain, those don't look very nice'. he says, you tell me, it's YOUR X-ray'. seems I collapsed my spinal column 20 years previous when I 'left the motorcycle' when I hit SAND on the road. ER doc only saw the busted right shoulder....
For past 5-8 years I do a 'silly' muscle stretch, and knock on wooden head, NO problems ,there... rest of the body, well, getting old ain't as much fun as 'they' said it wood be.
try to stay healthy guys !!!
Dirt Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2026 at 1:59am
1951… I sent you a PM
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2026 at 2:16pm
I had L3 &L4 fused in 1986 after 6 month I was aloud to go back the work, some days I feel like picking up things and other days I leave them alone
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2026 at 2:43pm
L5/Sacrum for me is fusing on its own, too much damage, arthritis and stenosis there for the Surgeon's comfort to do anything but leave it run.  That related to me in 2016, ten years later is worsening again.  Screwed mine up falling off a COE Road tractor onto a pile of Cribbing, been chasing issues for five decades now.  Doc did replace two Discs at C5/6 and C6/7, still wants to do C4/5 but at this juncture, I do not.
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2026 at 7:32am
The WD45 requires quite the procedure to get on and off, lots of twisting and leg lifting.  I often thought it would make quite a video if you recorded someone getting on and off a WD45, and then removing the tractor just to show the gymnastics.  The older I get, the more it feels like a Gemini astronaut in training.  I've had back surgery, every year its more of a challenge, but it was Dad's first new tractor, so I'll continue to conquer it, but still call it the Billy Goat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2026 at 7:37pm
I had given some thought to putting the seat on a 360 degree swivel and then lock it into place.  My attempt just didn't work out as you still had to do too many gyrations and it hurt.  Ya just gotta be careful and slow.  Gettin older is lots of fun!
Who was it that said; "If I knew I was gonna live this long, I'd have taken better care of myself."
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2026 at 7:33am
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2026 at 11:04pm
When you have a board that needs to be milled, there's two ways to do it:
Bring the board to the tool...
Bring the tool to the board.
From personal experience I'll tell you that, while discectomy fusions aren't fun, they're very much more tolerable than trying to live without.
If the mount and dismount is too difficult, then a solution is necessary- change how the mount/dismount occurs.  If operating the controls is hindered, then an alteration of the controls is in order.  Some may feel that it's heretical to modify a tractor to make it useable for you, but in my opinion, it is more important for you to be able to enjoy life operating your tractor, than to spend the rest of it looking out the window at your parked tractor.
Steve A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2026 at 10:07am
For what it's worth: I mounted a D-17 seat on one of mine by welding parallel 2"angle iron to a plate cut out to match the brake access, etc like the original seat. Goes back just far enough to clear implements. I heated the steering support and raised it as far up and over to the center as I could. Took off the toolbox and put a plate there to step on, then added a bolt-on removable step to the platform just above the drawbar. It can still pivot under that. Those make it easier for me. Herniated disk and sciatic issues. Also had my pant leg get caught on one of the latches a few winters ago and took a header off the back end on ice. That tore my left rotator cuff and motivated me to make alterations.   Considered getting orbital steering from a forklift and putting live hydraulics on it, but haven't had the ambition to start that one yet.
