Late curve stick wd |
Ol case mike
Topic: Late curve stick wdPosted: 12 Sep 2024 at 8:00am |
Is the rear gear ratio same as WD 45 vs curved stick Wd
Posted: 12 Sep 2024 at 8:02am |
Everything is the same if it has a curved stick. Straight stick trans and ring and pinion are different ratios.
Ol case mike
Posted: 12 Sep 2024 at 9:54am |
I thought it was a WD45 when I bought it curved stick with 45 block but motor has WD internals 1953 I believe is serial number on rear end thanks I was wondering about the rear end if was same as a WD 45 ratio
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5913 |
Posted: 22 Sep 2024 at 5:55am |
WD Trans., Curved Shifter, and Seat Support changes occurred at WD 127007. WD 201 Engine with side plate continued to the end of WD production. G |
