Late B gas tank
Matt Tallant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Topic: Late B gas tank
    Posted: 19 Jun 2026 at 10:15pm
Does the late Bs have the indention in the bottom for the starter switch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2026 at 10:32pm
if the starter motor is positioned with the SWITCH on top... then the tank has to have the Dent for clearance...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2026 at 6:39am
I need a nice tank with the indention in it
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 11:08am
I'm sure that's the same tank that's used on all CAs.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2026 at 1:38am
Same a CA tank, correct.
www.awtractor.com
A&W TRACTOR 920-598-1287
This page was generated in 0.101 seconds.
