Landscaping Advice with Tractor Use – Bes
arbordxb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote arbordxb Quote  Post ReplyReply Direct Link To This Post Topic: Landscaping Advice with Tractor Use – Bes
    Posted: 23 Apr 2025 at 8:08am
Hi folks,
I'm starting a landscaping project and wanted to hear from others who’ve used tractors or similar equipment for this kind of work. We’re working on a mix of residential and commercial plots – mostly leveling ground, preparing soil, and laying out planting areas.
I’d love some advice on:
  • Which implements work best for grading and soil prep?
  • Any Allis Chalmers models particularly well-suited for landscaping tasks?
  • Tips for managing smaller areas where big machinery might not fit?
Appreciate any tips or shared experiences—always something to learn from seasoned hands!
Thanks in advance!
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2025 at 9:00am
Rough or finish grading ?
For years I used a back blade on IH 460 Utility tractor along with rough grade with HD5G using bucket without teeth to smooth and level .
 Later I uses a land plane on my New Holland 785 skid loader , or just bucket on skid loader to smooth small areas .
 Using a Fiat Allis FD5 dozer now and finish with LX665 New Holland skid loader .
Depending on how large of area your doing depends on machine , what size truck you have to transport and how heavy of jobs you take on .
 I started doing driveway rock and grading , then bought HD5G and started doing dirt moving and trucking , digging basements and backfill foundations .
 Next I got certification for On Site Septic Systems - Design , Install , Soil Testing , Repair , and Inspections . So equipment changes as added Tractor Loader Backhoe, 2 1/2 yard 4 wheel drive loader , and other machines as needed .
 But first 5 years was the IH 460 , HD5G , Tandem dump truck and low boy trailer to haul the HD5 - the 460 I could move behind pickup on 4 wheel trailer .
  INSURANCE cost will dictate work also as what you can insure at right price , The GVW of truck govern costs and if you need a CDL license . Insurance if you need XCU coverage or extended liability , product liability , and the array of other coverages .
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 8:18am
Originally posted by arbordxb arbordxb wrote:
Hi folks,
Thanks in advance!
I use a 3-point hitch box blade to level small areas and a 3-point hitch roto-tiller for preparing soil prior to planting.
I'm curious as to what Allis-Chalmers equipment is available in Dubai? SmileConfused
BroseVino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BroseVino Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2025 at 8:29am
I had a similar setup with my compact tractor and found it way easier once I got some grading done first to even out the low spots. I also used https://lookdevisservices.uk for a rough material estimate and it gave me a good starting point without overbuying gravel. Saved me a couple trips. Just make sure your box blade is set right and you'll be surprised how much smoother it gets.
Edited by BroseVino - 04 Aug 2025 at 9:49am
