ISO: Gleaner E fuel pump
Chad (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad (MN) Quote  Post ReplyReply Direct Link To This Post Topic: ISO: Gleaner E fuel pump
    Posted: 17 Aug 2020 at 10:15pm
Looking to purchase new, or rebuild kit for E Gleaner fuel pump.  AGCO parts man says pump is no longer available and rebuild kit parts are too.  May be interested in very good used pump if can't find new. Would like to stay original if possible.  If all else fails, is there a suitable mechanical replacement?
Thanks in advance.
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2020 at 7:24am
I have a used one on the shelf. It worked when the engine was in the combine. I was talked into putting the engine in WD45. Steve Fisher might be able to help also.
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2020 at 8:31am
I have used ones thanks
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 8:23am
i know you said you wanted to stay orginal but i went with a electric fuel pump works great!
Steve g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve g Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2020 at 6:56pm
I have a gleaner e virtually intact been sitting for 20+ years keeping the motor and tires most everything else looks to be original from when it was parked
