ISO 190XT 3PT Sensing rod
MadCow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Topic: ISO 190XT 3PT Sensing rod
    Posted: 09 Oct 2026 at 8:12pm
I'm looking for part 0234574-1.
It's the 'sensing rod' that connects the bell crank to the 3pt lower arm on the right side of the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2026 at 8:35pm
With your draft arms let down to "level", grab a hold of them and see if they can move forward/backwards by pushing/pulling on them by hand. There should be basically zero movement. If there is, the torsion bar hex ends, left mounting bracket and bushings are worn out. That link rod is what sends the draft signal to the "Traction Booster" system to  transfer weight when plowing with a mounted plow.  The TB system is useless if things are worn out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2026 at 10:12am
I take it this is too much movement.
I suppose these are all scrap yard parts?
https://youtu.be/WrPoSMqK4JQ?is=XnE4hpWRIuvrMxos
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2026 at 10:23am
I do have a 3pt conversion for a snap coupler and I think it is tight I'll check that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2026 at 12:24pm
View of the movement at the hex head
https://youtube.com/shorts/JE8npiA3CZU?is=0jHdzk2vSp66XLLI
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2026 at 1:34pm
You shouldnt be able to pull against the stop by hand. Yes its too much play. Ive got a D17 ive got to fix
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2026 at 2:14pm
So looking at parts
11, 19, 20 in this pic? Is there any hope on 11 and 19? How warn is too warn? Anyway to repair them without CNC?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2026 at 2:37pm
With a milling machine and a indexer sure. I know a man that had thise parts repaired. I dont know what welding on the torsion shaft would do to the temper of it. It might take the spring out of it
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2026 at 6:18pm
The pictures confirm that while it is worn, it could still be considered functional because it isn't bottomed out on the rearward swing. Make/get a link rod and adjust as per owners manual.
