Is a cool running powerful 426 Possible? |
Page <123> |
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4594 |
Posted: 16 Jan 2019 at 6:26am |
I have a "On Highway " spec engine in my 220. It has a Simms injector pump and the same injectors tips as a 7080. I added an intercooler and the large waterpump which is necessary to get proper circulation through the intercooler. This required moving the lower rad inlet to the left side and in the process the rad was recored with 7 - 1/2" rows. With the stock pump setting, it dynos 190 hp. I can pull a 24' AC 1400 cultivator all day in 6th gear with no overheating problems
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29821 |
Posted: 16 Jan 2019 at 6:48am |
![]() Edited by Lonn - 16 Jan 2019 at 7:19am |
Wink I am a Russian Bot |
tornado8070
Posted: 16 Jan 2019 at 7:05am |
Finally someone did which in my opinion is the most gained aid in keeping them cool. Recoring and adding the 7th row of tubes. A no brainer for $150 to add 15% cooling compacity. |
09’ DT205B, 08’ DT220A, 83' 8070 MFWD, 83’ 8070 85’ 8050 MFWD, 83' 8030, 82' 8010, 85’ 6080 MFWD, 84’ 6080, 79' 7020, 85' M3 RWD, 85' 920 diesel,AC C-50 forklift.
Posted: 16 Jan 2019 at 7:13am |
An Engineer is caught between the Customer (who wants more for less $$$) and the Sales Dept (who wants things as cheap as possible to make more sales). If every tractor was equipped with a factory built oversized radiator and cooling system, Customers would always buy one size smaller than they need and "turn it up", knowing full well that the cooling system wasn't going to be an issue. Kind of like selling a lot of N-5's (and turning them up) versus selling N-6's. Customer could save several thousand dollars doing it that way.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5325 |
Posted: 16 Jan 2019 at 7:18am |
A radiator recored and an additional row of tubes for $150 ? I would like the name of the radiator shop that would do that !!!
Lonn
Posted: 16 Jan 2019 at 7:21am |
What does the standard radiator, recored, cost compared to recoring and adding an additional of tubes?
brandon190
Posted: 16 Jan 2019 at 11:37am |
"long time listener, first time caller"Sorry to butt in but I have an opinion. Love the forum but this is the first time I posted BC I have a little experience with this. Dig the 190xt, got two. dad bought a 8070 in the 90's W 21XX . Modern cab, great layout. Now, avert all who do not want to be offended. Ran hot, and not in the red, but boiling over. Wouldn't start on a block heater if It got around freezing. Had 170hp @ 2300rpm, wouldn't pull itself up a hill under 1900. Rebuilt pump, new injectors. Resleeved. New belts, water pump, boiled radiator. Had head done. Timed. Retimed. Had pump sent to a different shop. Retimed. New cam. new turbo. electric fans. advanced timing. retarded timing. Finally dad made a call, and 15k and the 8070 got I'm a 4455 Deere. Outside of diehard allis fans, I have never heard anything good about the 426. Rods are too small. Google allis 426, stay away from the allis forums and you will get your answer. Have at me guys.
shieldslx13
Posted: 16 Jan 2019 at 11:51am |
I think you are mistaking this for a JD forum.
shieldslx13
Posted: 16 Jan 2019 at 12:41pm |
Is there anyone on the forum with a phone number that I can talk to directly, with experience building these tractors? I have rebuilt more diesels than I can count, all successfully. I'm not being ungrateful in anyway but by overheat I mean boiling over, and a clean air filter and radiator was something that was done right off the bat. I can make my 6.5 diesel pull with a cummins, and I cant seem to make these work. A ph # would be beneficial.
Ron(AB)
Posted: 16 Jan 2019 at 1:27pm |
Shieldsix13,
What about the oil cooler? Did you clean it out on the overheating tractors? I've had the experience of cleaning it and making a difference cooling a tractor. We really would like to help. You can tell by how many people have responded and viewed the post. I have (4) 426 engines on my farm. Some are better than others, typically the lower the hours the better they are. But there is mods like putting higher compression pistons and different piston rings with less end gap to improve starting. There must be a solution because not all tractors/engines have the problem. |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12516 |
Posted: 16 Jan 2019 at 2:04pm |
Probably should have just kept listening.
Lonn
Posted: 16 Jan 2019 at 2:17pm |
No kidding!
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9260 |
Posted: 16 Jan 2019 at 3:07pm |
Calvin,you got me wondering...have you got the fast 4 gear? Is 6th the same in all 220's? Mine is set @170 & torques 210 and I don't believe I could pull 24ft in 6th with it in the ground. My old Wil-Rich 24ft was a load in 5th at 3in depth. |
AllisFreak MN
Joined: 07 Dec 2009 Location: Minnesota Points: 1631 |
Posted: 16 Jan 2019 at 3:39pm |
I just picked up a 1975 7040 last year and love it so far. Now all this 426 talk has me a little concerned. It has unknown hours but runs cool and smokes very little.
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8495 |
Posted: 16 Jan 2019 at 4:36pm |
I just got my first diesel this year, and it's a 301 non-turbo, so I'm still pretty new to the diesel world. I've combined with an L3 (426 engine) putting out 158 (-ish) horsepower, and it runs great, but...it's only got 1,400 hours on it. I've always looked at the 426 as a great engine, as long as they're not turned up too much like on the early 7080s and Gleaner N6.
Is there truth to the rods being weak and undersized? I did a quick search online and found this on an IH website, " If you pull a rod out of the AC you will find a straight cut rod cap as opposed to the IH 400 series and most other inline diesels with the angle cut cap. AC did this and had to sacrifice rod diameter and bolt size to pass the rod through the bore. The angle rod/cap can be much larger diameter and pass through the same sleeve" Edited by CrestonM - 16 Jan 2019 at 4:37pm |
tornado8070
Posted: 16 Jan 2019 at 5:10pm |
The difference between a 6 row and 7 row recore was roughly $150 last summer when I had my 8070 recored. Anyone be not willing to do this shouldn’t be pissin n moaning a tractor not staying cool. There are many other factors need to be considered that may also cause tractors to run warm. But for what I do custom baling on hot summer days the extra $150 is money well spent in demanding environments. Dr Allis we have been round about this before. I don’t understand why you are so against a 7 row of tubes....imo back in the day AC should have had these kids Installled from new. Back in the 80’s when these were new it surly wouldn’t have added more than $75 cost to build an 8070. I I sure as heck wouldn’t have been out buying a tractor strictly by radiator compacity. Ever AC tractor I’ve ever bought was in need of recore. This tells me they may have been undersized from new. |
Calvin Schmidt
Posted: 16 Jan 2019 at 8:00pm |
SteveM I don't think my 220 has the fast fourth. It's a real early one serial 1052.
SteveM C/IL
Posted: 16 Jan 2019 at 8:17pm |
I think mines a 70 model. Don't remember ser# and it's up the road.
Mikez
Posted: 16 Jan 2019 at 11:06pm |
Welcome to the forum to both of you. Brandon what part of ny are you from
Lonn
Posted: 17 Jan 2019 at 7:34am |
brandon190
Posted: 17 Jan 2019 at 7:49am |
Right outside Corning |
Mikez
Posted: 17 Jan 2019 at 8:12am |
Oh ok we're near Albany
brandon190
Posted: 17 Jan 2019 at 8:27am |
Yah that's about 3.5 hors from me
shieldslx13
Posted: 03 Apr 2019 at 8:30am |
UPDATE: Its been a long time, but I thought you might want an update...I received a call from my brother yesterday and gave me an update on the 7080 that together we put an HX35 (brand new one) on about a month ago. His words were "today I drove a turbocharged Allis 426 for the first time". He was so excited. Before this I kid you not, If it was below 2000 rpm it would not pull itself up a hill. And it has had 2 new turbo's on it (factory). Before we did this he said if it got no better he was going to sell and just go get an IH. For history, we have a 436 in an IH combine that will sing at 2700 rpm, start, and has GOBBS of power. Also due to not dumping loads of fuel without burning it, his EGT's were about 400 degrees cooler so it just sat on the thermostat the whole time. I know everyone is going to say the previous factory turbos were bad, but I asure you they were not. He said at 1600 rpm he could walk up a hill with 14lbs of boost!!!!! No black smoke. I believe the 7060 and 220 will be getting similar turbos. Also, I recently purchase a 4.8l 2000 Silverado with a 5 speed, 246k miles and changed the oil after 3k and it looks like it came out of the jug. (just gotta brag to someone who can appreciate old equipment that runs good, harder than you think!)
Ron(AB)
Posted: 03 Apr 2019 at 1:14pm |
Excellent!
Did it bolt right up without any mods? Pic? Keep us informed on the 7060 & 220 when they get the update. You may be starting a new trend! |
shieldslx13
Posted: 03 Apr 2019 at 1:53pm |
Took a bit of modifying, but worth it. It's like a different tractor. At 2550 it is a bit stronger, but its got 80 percent more power at 1600
shieldslx13
Posted: 03 Apr 2019 at 1:54pm |
And Ill try to get some pics from my brother but I'll definitely get them next time I go to the farm.
oldways
Posted: 03 Apr 2019 at 8:00pm |
This has certainly been one of the most entertaining threads I've read on here ! What part of KY are you in?
orangeman69
Posted: 03 Apr 2019 at 8:31pm |
we have a d21 series 2, a 210 and 7060,no troubles whatsoever with running hot,just commonsense maintenance and also we put 160 degree thermostats in.. made a big difference..
d17,d17nfpuller,d-17IVdiesel,d19gas,d19diesel nf,d21seriesII,180,190xtseries III,200,210,7020,7060,7080w/8.3cummins,8070fwa w/8.3cummins,8550 185 w/322 original hrs.
Lonn
Posted: 04 Apr 2019 at 6:50am |
Didn't read every reply but did you get advise from someone on putting on the HX35 turbo? Meaning, was this something someone else had experience with? My 7050 has never overheated since I've owned it but my brother's 7030 would. It had two scored sleeves/pistons though and after an overhaul and a rodded radiator it has been zero trouble. My L2 with a 426 has never had a heating issue either. Anyhow the HX35 turbo sounds like an interesting update to the 7080.
Page <123> |
