Information on 1948 WD with mounted plow
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Information on 1948 WD with mounted plow
    Posted: 15 Dec 2015 at 4:47pm
Our neighbour had an early row crop WD that was equipped with a 3 bottom hyd plow.
There was a frame that was mounted under the tractor with a pin connecting frame to the tractor were the snap couple attachment was connected when the s/c came out in the mid 50's.
The plow was attached to this frame. Does anyone recall seeing a plow like this. believe there was a chain on each side from the frame that was attached to each lift arm. Dick would plow all day long running the engine at 1/4 throttle and the governor would keep kicking in.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2015 at 9:31pm
I think you are talking about a "pin Hitch". that is what I get from your description, if I am right I have 2 of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2015 at 9:58am
Here ia a pin hitch plow although this is for a CA, thre was a similar one for the WD.
There was also a pick-up plow for the WD that bolted to the pin hitch drawbar after the drawbar bail was removed.
http://www.allischalmers.com/forum/uploads/3755/2_plow.jpg
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2015 at 7:52pm
The plow that Dick had was before this set up. Chains were used on each side from the plow to the lift arms and there was a large coil spring ahead of were the pin went in (were snap coupler would connect).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2015 at 7:17am
Are you talking about something like this?  Look at GrayRay's WD pic just a short ways down.
OOPS.....forgot the URL
http://www.allischalmers.com/forum/forum_posts.asp?TID=113705&title=whats-your-pride-and-joy-tractor
Edited by Ted J - 18 Dec 2015 at 7:18am
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2015 at 7:32am
Yes , that is the spring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2015 at 10:08am
That spring was common on WD's with plows up till the SC set-up anyway.
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2019 at 7:05am
My memory is a little vague but grew up with both and I'd say the answer is yes.  We started with 2-16's with the drawbar pull and later with 3-14's pin hitch pull.  With the first the drawbar has to float up and down and remember more than likely the pto shaft has to come out with both.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2019 at 7:20am
We ran a '49 WD with hitch pull. The PTO shaft didn't need to come out. The hitch pull was a little more complicated to hitch up, but it was a rock solid connection.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2019 at 11:17am
Some people call this the "beehive" spring.
It was an option when ordering the plows.
I would guess it was used for the drawbar
mounted plow on this particular tractor since
it has neither the pin hitch nor the snap-coupler
bell.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2019 at 12:10pm
I have a 2 bottom and a 3 bottom pin type. also a 3 bottom snap coupler type and a 4- bottom semi mount for a WD-45.
