Hydraulic cylinder piston removal. |
don k
Joined: 14 Jun 2026 Location: Bandera, Tx. Points: 29 |
Topic: Hydraulic cylinder piston removal.Posted: 02 Jul 2026 at 12:30pm |
What is the secret to get the piston out of a moldboard lift cylinder AC model D grader. Thanks
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42484 |
Posted: 05 Jul 2026 at 11:19am |
Seems every cylinder company has their own way to determine what holds the end cap or rod seal gland to the body . Each has a simple design that defies logic .
External threads on barrel , gland held in by snap ring you can see , gland held in by hidden snap ring - or some other mysterious method . Tyrod cylinders , threaded ends , snap rings . Should be some form after inspecting the end to figure out the secret
Les Kerf
Posted: 05 Jul 2026 at 12:16pm |
Some cylinders require removing the pipe fitting to expose the innards to allow removal of the hidden snap ring. I dunno about yours
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 5015 |
Posted: 05 Jul 2026 at 5:39pm |
It seems as if there is a compotation between engineers to add something no one else has done yet. Wither it is really an improvement or not.
don k
Posted: 06 Jul 2026 at 8:36pm |
I have removed the two internal nuts that go against the packing. As far as I can see the piston should now slide out. But it doesn't.
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 913 |
Posted: 06 Jul 2026 at 9:19pm |
If that piston has spanner holes and has threads toward the outer side you will have to loosen that to get it out
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
8070nc
Posted: 06 Jul 2026 at 9:22pm |
Just a guess. My D17 series 4 was like that untill i changed it to later style cylinders
1984 80780
don k
Posted: 08 Jul 2026 at 6:04am |
I looked again at the service manual and the inside of the cylinder. There is nothing holding the piston except seals. I am going to chain it to something and pull on it with a hoist and see what happens.
don k
Thanks(1)
Posted: 12 Jul 2026 at 2:34pm |
I got it apart. Tied one end to my grader and the other end to my kubota. Jerked it apart. Now to find seals for it.
