Hills, Hollers, Creeks, and the Ground We Stand On |
Page <123 |
BuckSkin
Joined: 12 Sep 2019 Location: Poor Farm Points: 1443 |
Posted: 14 Sep 2026 at 5:38am |
Saturday_22-August-2026 As Seen at Green River Dam Green River Dam Tailwater Originating near King's Mountain in Lincoln County, Green River flows 384-miles to it's mouth on the Ohio at Spottsville in Henderson County. Construction of the dam began in 1964 and was completed in 1969; the lake behind the dam covers 8,200 acres. The dam is 141-feet high and 2,350-feet long(0.45-mile). The dam is at river mile 305.7; Greensburg is 26 river miles downstream; it is 9-miles at Heading 273.59° as the Crow flies from the top of the dam to the KY61 Green River Bridge at Greensburg, 17-miles farther by river. Campbellsville - Taylor County - Kentucky 37°14'43.78" North Parallel - 85°20'29.82" West Meridian 615' Above Sea Level
BuckSkin
Posted: 15 Sep 2026 at 6:02am |
Saturday_22-August-2026 As Seen below Green River Dam Warning Signs at Green River Dam Boat Ramp Looking Upstream at Green River Dam Boat Ramp Campbellsville - Taylor County - Kentucky 37°14'29.50" North Parallel - 85°20'38.57" West Meridian 656' Above Sea Level |
BuckSkin
Posted: 15 Sep 2026 at 4:48pm |
Saturday_22-August-2026 As Seen from Green River Dam Boat Ramp Looking Downstream 1977 KY Hwy 55 Green River Bridge KY Hwy 55 Mile #2.6(31) Green River Mile #305.1 As close as I can find, this bridge was built about 1977\78; I know for fact that in early spring of 1978 old KY55 crossed back and forth over the new construction numerous times between Columbia and Campbellsville. The creation of this bridge was a huge improvement over the treacherous hill and dead-man's curve on the South end of the Tebb's Bend one-lane Iron Bridge next downstream from here. Campbellsville - Taylor County - Kentucky 37°14'29.50" North Parallel - 85°20'38.57" West Meridian 656' Above Sea Level
BuckSkin
Posted: 9 hours 14 minutes ago at 1:35pm |
Saturday_22-August-2026 As Seen at Green River Dam Green River Dam Standpipe Control Tower The flow of water under the dam is controlled within this tower. From the point where the water enters this stand-pipe, through the Dam, until it exits on the other side = 703' at 211.13° The Dam itself lies at 151.09° If my math is correct, the river flow passes under the dam at an angle of 60°; there must be a reason for this instead of going straight through at the center. The bulk of what you see is Robinson Creek; Green River disappears to the left in a narrow channel between that point of trees in the left midground and the line of trees in the background; the majority of the Lake is water backed up in Robinson Creek. This is the first time I have ever seen this when there weren't at least a hundred Buzzards perched all over the top; zooming in close reveals what looks to be "hot wire" electric fence around the top edge and it is probably also stretched back and forth across the top; maybe I'm wrong and it isn't hot wire, but that would explain the absence of Buzzards. Green River Mile 305.8 Campbellsville - Taylor County - Kentucky 37°14'51.20" North Parallel - 85°20'24.30" West Meridian 690' Above Sea Level Photos taken Through the Glass of a Moving Vehicle
Page <123 |
