Hills, Hollers, Creeks, and the Ground We Stand On
 Post Reply Post Reply Page  <123
BuckSkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2026 at 5:38am
Saturday_22-August-2026
As Seen at Green River Dam
Green River Dam Tailwater
Originating near King's Mountain in Lincoln County, Green River flows 384-miles to it's mouth on the Ohio at Spottsville in Henderson County.
Construction of the dam began in 1964 and was completed in 1969; the lake behind the dam covers 8,200 acres.
The dam is 141-feet high and 2,350-feet long(0.45-mile).
The dam is at river mile 305.7; Greensburg is 26 river miles downstream; it is 9-miles at Heading 273.59° as the Crow flies from the top of the dam to the KY61 Green River Bridge at Greensburg, 17-miles farther by river.
Campbellsville - Taylor County - Kentucky
37°14'43.78" North Parallel - 85°20'29.82" West Meridian
615' Above Sea Level
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2026 at 6:02am
As Seen below Green River Dam
Warning Signs at Green River Dam Boat Ramp
Looking Upstream at Green River Dam Boat Ramp
37°14'29.50" North Parallel - 85°20'38.57" West Meridian
656' Above Sea Level
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2026 at 4:48pm
As Seen from Green River Dam Boat Ramp Looking Downstream
1977 KY Hwy 55 Green River Bridge
KY Hwy 55 Mile #2.6(31)
Green River Mile #305.1
As close as I can find, this bridge was built about 1977\78; I know for fact that in early spring of 1978 old KY55 crossed back and forth over the new construction numerous times between Columbia and Campbellsville.
The creation of this bridge was a huge improvement over the treacherous hill and dead-man's curve on the South end of the Tebb's Bend one-lane Iron Bridge next downstream from here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2026 at 1:35pm
Green River Dam Standpipe Control Tower
The flow of water under the dam is controlled within this tower.
From the point where the water enters this stand-pipe, through the Dam, until it exits on the other side = 703' at 211.13°
The Dam itself lies at 151.09°
If my math is correct, the river flow passes under the dam at an angle of 60°; there must be a reason for this instead of going straight through at the center.
The bulk of what you see is Robinson Creek; Green River disappears to the left in a narrow channel between that point of trees in the left midground and the line of trees in the background; the majority of the Lake is water backed up in Robinson Creek.
This is the first time I have ever seen this when there weren't at least a hundred Buzzards perched all over the top; zooming in close reveals what looks to be "hot wire" electric fence around the top edge and it is probably also stretched back and forth across the top; maybe I'm wrong and it isn't hot wire, but that would explain the absence of Buzzards.
Green River Mile 305.8
37°14'51.20" North Parallel - 85°20'24.30" West Meridian
690' Above Sea Level
Photos taken Through the Glass of a Moving Vehicle
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2026 at 12:36am
Wednesday_10-June-2020
As Seen on KY Hwy 1730 at Manntown
Electrical Transmission Lines along and across the Cumberland River just below The Dam
Westbound on (Old)KY Hwy 1730 at Milepoint #0.76(from Old US127)
The Cumberland River flows Left(Downstream) and Right(Upstream) across the photo and is just right there beyond the two big poles.
Wolf Creek Dam is just out of the photo to right.
The lines going left and right across the photo have originated at Wolf Creek Dam.
The lines hanging from these two big galvanized poles proceed steeply down to a triple set of like poles, the tops of which are barely visible in the next photo, and then angle across the river to one of those big towers carrying many more wires, better explained in the second photo.
In the far distance, just to the right of the right-most pole, is a sheer bluff; I have decided that must be on Jump Off Road.
36°52'17.57" North Parallel  85° 9'14.61" West Meridian
853' Above Sea Level
The lines hanging from the two big galvanized poles in the previous photo connect to a triple set of like poles, the tops of which are barely visible in the bottom-left corner of this photo, and then angle across the river to that big tower that you see.
In the center of the photo, in the far distance, is that same sheer bluff that I have decided must be on Jump Off Road.
36°52'18.09" North Parallel  85° 9'15.75" West Meridian
848' Above Sea Level
We are on the old original road-bed of KY1730, just beyond where the new route diverges from the old; just recently, they have blocked passage on this old path.
If you remember the old original road and were to travel on the new, you wouldn't recognize where you were at, they have changed it that much.
Photos Taken through the glass of a Moving Vehicle
Westbound KY Hwy 1730 - Manntown - Russell County - Kentucky
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2026 at 9:08pm
As Seen from KY Hwy 1730 at Manntown
Distant Grain Bins in Rock Lick Creek Bottom
Westbound on (Old)KY Hwy 1730 at Milepoint #1.44(from Old US127)
Camera Location:
36°52'35.59" North Parallel  85° 9'45.55" West Meridian
692' Above Sea Level
We are on the old road bed and at a lot higher elevation than the new; we are up HIGH, else we couldn't see those Grain Bins; whereas, the new road to the West of us is at river bottom level.
From Camera to Grain Bins = 0.43-mile at 271.92°; almost exactly dead West and a hair West by North.
The Grain Bins are in Rock Lick Creek Bottom, between Rock Lick Creek to the East and Salt Lick Creek to the West; with Manntown Road in front of them on the South side and the banks of the Cumberland 320-yards behind them to the North.
The Grain Bins:
36°52'36.37" North Parallel  85°10'13.76" West Meridian
601' Above Sea Level
Alas, we will never get to see this view from a vehicle again.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2026 at 9:20pm
alot of nice and intersesting ccountry
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2026 at 9:26pm
Thanks for looking and thanks for the comment.
You can click on the pictures and they should get bigger and also you can then zoom in on details.
