Help ID'ing D15 Loader |
Ben.N
Joined: 06 Sep 2011 Location: East Aurora, NY Points: 1 |
Topic: Help ID'ing D15 LoaderPosted: 11 Sep 2011 at 12:55pm |
Last summer I purchased my grandfather's 1960 D15 serial number D15 1018 with loader, auger and back blade. He bought it used. It's latest paint color is Allis orange, but beneath that looks to be industrial yellow. This winter, both bucket roll cylinders developed massive rod seal leaks and I'm in the process of rebuilding the worst of the two. The rod chrome is badly worn near the mounting trunion and there is a flat spot closer to the piston head. As an alternative to reworking the rod I'd like to try and find a used cylinder in better condition. The problem is I'm having no luck identifying the loader model in order to track down replacement parts (presumably knowing the loader model would also help in identificaiton of the correct seal packs and if I was EXTREEMLY lucky even the torque specs). So the purpose of this post is to solicit the expertise of you folks in identifying this loader or at least pointing me in a direction to look for loaders that would have been offered with this machine. I haven't found any significant markings on the loader itself, but I wouldn't know where to look. Help in that area would be useful as well. Attached is a photo. Any help would be appreciated. Thanks.
Brian S(NY)
Joined: 13 Sep 2009 Location: CherryValley,NY Points: 3383 |
Posted: 11 Sep 2011 at 2:45pm |
Lookis very similar to the one on my d-15 II except that mine is a trip bucket. I will look at the one on my other 15 II which is a henrey.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7722 |
Posted: 11 Sep 2011 at 8:03pm |
Any hydraulic place can fix those cylinders as good as new for you. Any used one you may find could be just as bad as what you already have.
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4590 |
Posted: 11 Sep 2011 at 9:33pm |
You have a D-15 industrial with the extra reinforcing on the front axle. The loader is a Henry but I'd have to do some reasearch to get a model number. As stated, any good hydraulic shop will repair the cylinders. |
allisnut
Posted: 19 Sep 2011 at 10:25am |
It looks like a Henery TS500 like on my d15 industrial that also has a Henery Mark IV Backhoe on it
Breeze
Posted: 19 Sep 2011 at 12:07pm |
Looks to be a Henry L100 front loader, my d15 also had a henry mark iv hoe on it. Napa made all hoses for me, cylinders we removed and took to hydraulic shop next door to the sawmill wood yard we deliver to. Picked em up a week later and no problems up to when she sold. I do like the grill guard on yours better than the small flat steel one I had on mine.
64 D-15 Industrial
Posted: 10 Feb 2012 at 10:13pm |
I have a 1964 D15 with a Henry TS-500 loader (as well as a Henry Mark IV Backhoe). I also have all the manuals for parts and operation. I can send you pictures of mine if you like and or diagrams off the manuals.
orangeman
Posted: 11 Feb 2012 at 6:55am |
Ben N. As the other boys have said, a good hydraulic shop will be able to help you out. If rod and other appurtenances of the hydraulic cylinder need replace, go here:
http://baileynet.com/hydraulics/bailey_hydraulics_rod_and_tubes HTH's - Orangeman Jai Guru Deva, Om
Edited by orangeman - 11 Feb 2012 at 6:58am |
