hd7g-b loader transmission filter |
onehite
Topic: hd7g-b loader transmission filterPosted: 06 Oct 2013 at 8:33pm |
Where is the main transmission filter located at on a 7G B series loader, and what does it look like? I have no transmission pressure and I want to see if it clogged.
Dozer
Joined: 16 Aug 2011 Location: SW New York Points: 689 |
Posted: 07 Oct 2013 at 7:34am |
On the RH side of the transmission case between the transmission oil pump and the transmission control valve. On my machine it is a can type filter. Allis Chalmers used different suppliers so your filter might look different. There is also a screen low on the RH side of the case that should be checked. It is a square plate with (4) 1/2 bolts and a hose. The oil is going to come out when you remove this.
onehite
Posted: 07 Oct 2013 at 10:02am |
Are both of these accessed from under the loader?
Dozer
Posted: 07 Oct 2013 at 5:19pm |
Yes I do not know if it can be done from the top. I would start the motor and use the bucket to raise the track, put something under the track to give you more working space. Then raise the bucket and support the bucket 2ft or more above the ground. crawl under from the front. That is how I would do it but do whatever works for you.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 36529 |
Posted: 07 Oct 2013 at 8:17pm |
This is the trans suction screen from my 7G, it is not a 7G-B but I have been told they use the same transmissions. It is located on the left(as you sit in the seat) on the trans face. There should be a canister filter mounted to a bracket between the trans and the torque converter, the filter retainer is on top and it can be pulled from above but the strainer has to come out from the bottom side.
mmors
Posted: 08 Oct 2013 at 1:20am |
Dozer
Posted: 08 Oct 2013 at 7:05am |
Thanks for the picture. The screen on my machine is different but similar. My point is that Allis Chalmers was constantly changing (hopefully improving) the equipment.
DMiller
Posted: 08 Oct 2013 at 7:56pm |
Dozer, you talking of the small screen in the bottom of the trans? There are two strainers, this one is where the trans pump on the torque converter and the steering pump take suction on the main case, about halfway up the face of the trans. The parts guide I have doesn't show but two variants(page 198) and those were for the changes to the fittings coming out of this screen.
Edited by DMiller - 08 Oct 2013 at 8:01pm |
doctorcorey
Joined: 17 Jul 2011 Location: S. KC Missouri Points: 589 |
Posted: 09 Oct 2013 at 10:17pm |
Dmiller is right, trans practically interchange between A and B model. Mine appears to be a HD7GB trans in an A model, and filter is below your left leg in front of case. If it's clogged completely, usually you will see erratic operation in the steering and brakes as well, as the steering pump suctions off of trans filter, too. BTW, I still have a B model pump for sale.
doctorcorey
Posted: 09 Oct 2013 at 10:23pm |
bebeeells
Joined: 18 Aug 2016 Location: New York,USA Points: 3 |
Posted: 18 Aug 2016 at 1:24am |
Cheap CSGO Skins |
Tigerhaze
Joined: 20 Apr 2020 Location: West Central MO Points: 10 |
Posted: 22 Apr 2020 at 4:52pm |
I have a HD7G-B that apparently has symptoms related to transmission fluid starvation but occurs even more rapidly (within a minute or so), especially when trying to turn. I suspect it may be because of the clogging issues indicated here. My question is when going underneath, is there a belly pan that has to be removed to access and if so is it difficult to access the mounting bolts and/or lower the pan from the frame? I know it is likely heavy but am wondering more about horizontal clearance. Hopefully I don't have to remove or it is easy.
Also does anyone have a filter part number I can cross? Thanks in advance.
DMiller
Posted: 22 Apr 2020 at 6:01pm |
Six bolts(originally) hold the trans belly pan up, it by itself is Not heavy as much awkward, as far as what has accumulated in it can be concrete, use a simple automotive style hydraulic jack under it when get to last two bolts.
The way the trans pump works is takes a scavenge suction thru a screen bottom of trans case, sends that to left side clutch case which feeds oil to the larger screen sump, which in turn feeds the Second side of the trans pump and feeds oil to the trans shift/lube system. The large screen sump starves the whole system starves steering is feed from there as well. The Trans filter is not suction but pressure side, as are the steering filters on my 7G, I am not sure as to how the G-B filtered steering pump pressure side but should be a separate system. |
DMiller
Posted: 22 Apr 2020 at 6:12pm |
These are permanent screens, washable. Just got on MINNPAR Site, on the 7G-B parts guide and is set up exactly as noted. Page 110 for Trans pump layout page 138 for steering pump layout. One filter for each on Pressure side. Trans kit 70667661 or 70679513, steering kit 70631828
I have only been able to find filters for mine thru Baldwin. Napa here will not even try to find them in their system so stopped asking them. My supplier is Applications Associates and has machine guides to search thru. Usually two to three days ship time. Just look up Baldwin filters as a search. |
DMiller
Posted: 22 Apr 2020 at 6:24pm |
To access the screens will need to drain the entire system, some 20 gallons oil. 10W hyd trans oil a Hytrans fluid. Are three drain plugs on bottom of main housing, Center is basic trans/bevel gear, the other two are clutch sections and are separate. Will be around a gallon to two in the trans sump when drain it at screen(Four 1/2" bolts).
DMiller
Posted: 22 Apr 2020 at 6:25pm |
Some days wish had found a G-B as had pedal steer and the 3500 engine. Others glad I found what I have.
Tigerhaze
Posted: 23 Apr 2020 at 12:13am |
Thank you so much for the helpful information- I think I would have been really leery of this crawler if I hadn't known about this issue which seems to be common to all of them. I know quite a bit about JD crawlers but not so much on Allis machines.
FYI I also own an Allis loader- a TL14A so probably will be having questions about it at some point.
Tigerhaze
Posted: 27 Apr 2020 at 6:54pm |
I appreciate the discussion- when comparing to the photos and the parts manual I better understand the system and what I am getting into. Sorry to be a pest (always hate to say that on these kinds of discussion forums )but have a few follow up questions on this.-Steering Pump Oil Screen: I saw you can clean this, but was wondering about where to get the gasket (AC part 70623805)? I would assume it would be destroyed when removing the screen to clean it. It appears to be cork or leather in the photos so I could try to stencil and Exacto knife one with cork or felt gasket material but I hate doing that if I can help it. If not available, any suggestions on gasket material? -Transmission Filter element: Is there truly a difference in the element between early and later 7G-B serial numbers? When I cross on Baldwin filters, they show the early as a PT498 and the late as PT498-10, but if you search by application the 7G-B is listed only as the PT498-10. I looked at the dimensions and they are the same (including gasket), just a different UPC. The reason I ask is that I won't know the serial number until I get to the crawler to change filters. I suppose I can order both and return the wrong one but was curious. -Transmission Filter element: Does the Baldwin element come with the housing seal (AC part number 70666244)? The photo on Baldwin's site doesn't show it and not sure where to get it otherwise but would assume it would be destroyed when removing the old filter. Thanks in advance.
DMiller
Posted: 28 Apr 2020 at 7:33am |
The baldwin filter kits come with O-ring(s), reinforcement rings and the bolt head seal. The -10 series may just be a slightly finer filter which at this stage is not a requirement for the older machines. The filters themselves have a fibrous seal top and bottom that seal the elements to the can/head.
As to the Screen filter gaskets, I have had to make my own for my tractor as NLA. Sheet material available at any parts house will work and is fine as nothing is dimensional required. Edited by DMiller - 28 Apr 2020 at 7:35am |
Braswell
Joined: 14 Feb 2024 Location: North Carolina Points: 49 |
Posted: 20 Jul 2024 at 12:55pm |
Hey Doctor,
Do you have any parts for an Allis Chalmers Hd7gb ? Randy in North Carolina 3364515881 |
doctorcorey
Posted: 21 Jul 2024 at 8:41am |
Sorry no, I had a 7A. DMiller has(d) a 7b I believe. Gemdozer likely has parts, too.
Semper Fi USMC 1958 HD6G, 1959 MF 203 loader, 1960 Case 420B Backhoe, MF 65 Tractor/Loader Diesel
gemdozer
Posted: 21 Jul 2024 at 6:49pm |
I am still have a small invintory parts for HD7GB
Braswell
Posted: 22 Jul 2024 at 6:41am |
Send me a phone number, I’ll call today
Braswell
Posted: 24 Jun 2026 at 6:38am |
This is Randy for NC… are you still monitoring this forum ???
Braswell
Posted: 24 Jun 2026 at 6:39am |
Are you still monitoring this forum, I have a 7GB question
Braswell
Posted: 24 Jun 2026 at 6:40am |
Hey I’m back… Randy here in North Carolina with a 7GB
gemdozer
Posted: 24 Jun 2026 at 7:04am |
I am still have a small inventory used parts for HD7GB
Larry O F
Posted: 29 Jun 2026 at 2:25pm |
Do you have a good starter solenoid for my 7gb track loader? we have done business with you before.
Thanks, Larry
gemdozer
Posted: 29 Jun 2026 at 2:49pm |
HI I should have 1 startor solenoid but if you have the parts number on it will help.
HECTOR
