HD5 radiator
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Topic: HD5 radiator
    Posted: 23 Jan 2010 at 11:59am
I need to replace or have the old rebuilt as repairs only seem to last a little while and is leaking again.Local radiator shop wants $430 to re core the old. Anyone know were I could get one cheaper?I know I could check used part,but with out pressure check it may not be any better than the one I have which looks good but leaks.Thank for any ideas.
Ray
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 6:17pm
try pepper to stop the leaks. works just as good as bars leak. recore price seems high, is that from a local radiator shop or dealer?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 6:32pm
I had mine recored a few years back and it costed me arond $600.00. The reason that these cost more to recore is that they are a non std. core and have to be coustom built. If you use the machine a fair amount then i would just spend the money on a new core. THis way it  will never leak again unless something gets ran in to it.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 7:32pm
That is not a bad price on that core. Gary
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 9:58pm
I found a complete unit including the hardnose frame for $150 from a used parts dealer. Said i had to have it checked for leaks so he knocked off $25 to fix it if it had any leaks . NOT one leak and was perfect .
 Lot of parts machines still around , do some searching you might find a good used one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 8:22pm
Thanks for the information,it is time to have a radiator that I don't have to think about all the time.This tractor has been getting less than a 100 hours a year but it needs to be ready to go when I need it which is in the winter most of the time so it was always a problem when it would start leaking again.I have used a lot of used part over the years but none of  places I used to do business are in business or they have gone to wheel tractors only.This is something I don't want to buy with out looking at it first and have faith in person I'm doing business with.
Ray
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 8:45pm
Ray, get on the CB and find a good truck radiator repair shop.  I just put a re-cored radiator in my D-15 (II) wheel tractor, cost me $ 450.  A good radiator shop is hard to find, nowadays, due to all the EPA regs.  A good place to take a leak is  damn near priceless!
acisbest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acisbest Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 6:16am
About 4 years ago I had my HD6G radiator re-cored by a local radiator shop. Around $400 back then... I knew it was shot so I brought it in... Guy called me up and asked me to come down and see it in his leak tank. I told him that I'm sure it was an impressive site but I was aware it was shot, just fix it. He fixed it but when I went to put it in the mounting holes did not line up, there was no tolerance within the HD6G mounting area... I had to take it back out and make a jig for the radiator guy to fix the mounting holes...
Then, a few years later it leaked again, the bottom shell of the radiator had rotted out around the new core.. Back again.... Getting the radiator in and out is no easy task on the HD6.... For the last few years its been holding...
Edited by acisbest - 25 Jan 2010 at 6:17am
