Gleaner K2 corn head alignment problem |
dertz19
Joined: 22 Sep 2009 Location: Minnesota Points: 105 |
Topic: Gleaner K2 corn head alignment problemPosted: 09 Oct 2026 at 9:42pm |
I purchased a '78 K2 Corn/Soybean Special a couple years ago, that came with a grain head. This spring I acquired a low profile black A330 corn header, from a gentleman who had used it on multiple K2's for his test plot business. I assumed these would be similar vintage and align.....I discovered that the sprocket on the cylinder drive shaft on the combine is about 1" off to align with the innermost sprocket on the corn header. Any advice?
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3740 |
Posted: 09 Oct 2026 at 11:25pm |
You need the double 13 tooth sprocket on the thresher countershaft - will try to get pn tomorrow.
dertz19
Posted: 09 Oct 2026 at 11:40pm |
A double sprocket was what I was suspecting... I've got parts books and manuals I've been researching- are both sprockets the same size- 13T? For a K2? I've got a parts book that shows an inner 13 tooth sprocket and an outer 25 tooth sprocket, for a K2.
Thanks!
Jordan(OH)
Joined: 11 Sep 2009 Location: Celina, OH Points: 1590 |
Posted: 10 Oct 2026 at 6:51am |
25T is for a wide row head.
dertz19
Posted: 10 Oct 2026 at 10:36pm |
Thanks for the help!
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3815 |
Posted: 11 Oct 2026 at 6:51pm |
That A330 cornhead us a nice combo to the Gleaner K or K2.
Edited by AC7060IL - 23 Oct 2026 at 10:59pm |
dertz19
Posted: 21 Oct 2026 at 8:36pm |
Update on this, the correct sprocket turned out to be the 13T and 25T combo sprocket, with a 330 corn head driven off the 25T sprocket. Oakley Salvage in North Carolina did not have one, but he indicated AGCO still sells the part which in fact, turned out to be the case, Part # 70575291.
I would have thought a Corn/Soybean special would have had the 13T/25T sprocket but maybe someone switched it out at some point....
