Gleaner 10bolt 5” spacers
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner 10bolt 5” spacers
    Posted: 05 Apr 2019 at 8:11am
Dished out my Gleaner’s Drive wheels to track differently, but need an additional 5” spacer on each wheel. Did Gleaner mfg such an item? It’s for a 78’ k2 that has the 10 bolt finals.
Edited by AC7060IL - 05 Apr 2019 at 8:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2019 at 12:55pm
I'm sure the answer is no.
What are you trying to accomplish? Get tires off the row? Good luck! Get an A2. It will track between the rows.
soybreedingboy77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soybreedingboy77 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2019 at 10:28pm
I put some 9" spacers on my F2 10 years ago. Ordered them from Unverferth. Less than $1000 if I remember.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 9:13pm
Before you put spacers on, remove final drives, remove cotter pin through adjusting nut and axle, drill to 1/4 and drive roll pin through nut and axle. MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 9:36pm
yeah. I didn't know about the shearing cotter pin deal till I had put mine back together .Yes it was the left side and yes the bin has had something like 2 ft added to right side.They did a good job. Looks factory.
