Generator
Neegan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Neegan Quote  Post ReplyReply Direct Link To This Post Topic: Generator
    Posted: 17 Jun 2022 at 4:36pm
Anyone have the part number for the generator that fits a 1968 HD16DP  S# 8706? Don't have a parts manual but my service manual doesn't give me the number.  Thanks
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2022 at 6:50pm
Try the parts manual on line at MinnPar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Neegan Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2022 at 9:33pm
Thanks, I found it right there.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2022 at 7:02am
If'n it were me I'd upgrade that charging system using either a 20SI, or 33SI series Delco alternator myself. The old generators were good no doubt, but brushless alternators have many less parts to wear and require no periodic maintenance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Neegan Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2022 at 11:59am
Well I found that the generator is working so I'm going to replace the regulator. I don't think the regulator should rattle if you shake it. Big smile
I'll look into changing over to an alternator when this generator gives up. Thanks
Lee Bradley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lee Bradley Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2022 at 11:39am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2022 at 6:30am
FYI.. that unit needs an external regulator....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Neegan Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2022 at 9:07pm
Thanks for the info gentlemen.
