gear reduction box
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: gear reduction box
    Posted: 04 Dec 2025 at 12:50pm
while i am continuing my search for some low gears for my 37wc  has anyone fabricated a gearbox to go were the lift shaft gear box is
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2025 at 1:00pm
Yes: There was an aftermarket 2 speed that was either overdrive on underdrive. The underdrive is just want you're looking for if you've gone to big tall tires and don't have the power for them.
  Find a set of tires that will work for what little power you have and you'll do just as well in the long run.  I've encountered many that swear that to beat those with tall tires, you must also have tall tires. I call BULL$HIT on that. You MUST have tires that work with your available HP, Gear ratio, Balance and track conditions.
  I pulled a CA for nearly 30 years and could consistently beat Oliver 66s and Farmall C/SuC and Case VACs with my 24" tires.
 Unless you're pulling on the same track with the same weather condition and same preparation each time it will take a lot of track reading and different size tires to find something that works, but after you do all the clubs will start changing the rules on you like they did to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2025 at 1:02pm
wondering about taking some gears and shafts out of awd trans and seeing what icould come up with and fab a case for them
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2025 at 5:00am
My '48 WC has a Sherman Underdrive either from AC or the original Dealer. High range is 1:1 and Low range is 1.4:1.
Edited by Phil48ACWC - 05 Dec 2025 at 5:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2025 at 9:48am
don t see any shermans around or i would have it allready     plenty for 9n fords
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2025 at 11:54am
I have a complete WC Hi-Crop rear end with the 6.6:1 ratio that I might consider selling. This is the same ratio as an RC.
