Gas tank |
john2189
Joined: 11 Sep 2009 Location: Minerva,Ohio Points: 448 |
Topic: Gas tankPosted: 6 hours 50 minutes ago at 8:53am |
For storage over winter, is it better to have a full tank or empty to minimize rusting?
'41 Allis B
'49 Farmall Cub |
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6687 |
Posted: 4 hours 28 minutes ago at 11:15am |
Full, less space for condensation.
Joined: 11 Sep 2009 Location: illinois Points: 93270 |
Posted: 2 hours 51 minutes ago at 12:52pm |
I think it depends on where you live. Hubert has a lot of high humidity in his area.. Where i live the humidity is very low in the winter. I like to keep the tanks as low a possible to keep the posibility of gas going bad.. Normally gas in our area is good for several months ( even the 10% ethanol)... but i run the tanks low, then put a couple gallons back in during april / may and fire them up for the summer.. Never have a carburetor plugging problem. .. also have pretty good luck with no oxidizing of the magneto point... They just fire up after setting 5-6 months..
Got a CASE 530 backhoe with a distributor.. do the same with it.. it can set 6 months at a time, no problems. Edited by steve(ill) - 2 hours 50 minutes ago at 12:53pm |
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 5015 |
Posted: 1 hour 3 minutes ago at 2:40pm |
Factors other than humidity come into play. I bought an old Cat had been sitting in a barn out in a country that only averages about 8 inches of rain a year. I have relatively low humidity at my place 50 miles west with 20 inches of rain average. So this had to be lower humidity yet. I have never seen rust like this tank had. An L shaped tank and over 2/3 full of old time diesel that burned just fine once filtered from the rust. But a very good example of what happens to tanks not full of fuel.
