Gas tank
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Topic: Gas tank
    Posted: 07 Oct 2026 at 8:53am
For storage over winter, is it better to have a full tank or empty to minimize rusting?
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2026 at 11:15am
Full, less space for condensation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2026 at 12:52pm
I think it depends on where you live. Hubert has a lot of high humidity in his area.. Where i live the humidity is very low in the winter. I like to keep the tanks as low a possible to keep the posibility of gas going bad.. Normally gas in our area is good for several months ( even the 10% ethanol)... but i run the tanks low, then put a couple gallons back in during april / may and fire them up for the summer.. Never have a carburetor plugging problem. .. also have pretty good luck with no oxidizing of the magneto point... They just fire up after setting 5-6 months..
Got a CASE 530 backhoe with a distributor.. do the same with it.. it can set 6 months at a time, no problems.
Edited by steve(ill) - 07 Oct 2026 at 12:53pm
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2026 at 2:40pm
Factors other than humidity come into play. I bought an old Cat had been sitting in a barn out in a country that only averages about 8 inches of rain a year. I have relatively low humidity at my place 50 miles west with 20 inches of rain average. So this had to be lower humidity yet. I have never seen rust like this tank had. An L shaped tank and over 2/3 full of old time diesel that burned just fine once filtered from the rust. But a very good example of what happens to tanks not full of fuel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2026 at 3:53pm
I live in Ohio long cold winters. My garden tractors have plastic tanks so I am not worried about them.
'41 Allis B
'49 Farmall Cub
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2026 at 11:12pm
I seem to leave all my gassers empty and diesels full, last time I left a gasser full (steel tank) over winter the gas ended up with water in it and cracked the sediment bowl also messed the carb up.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2026 at 8:51am
I use Sta-bilt in all of mine for the winter and don't have trouble .
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2026 at 7:35pm
I use stabil 360 year long
'41 Allis B
'49 Farmall Cub
This page was generated in 0.107 seconds.
