G160 for CA |
1955allisca
Topic: G160 for CAPosted: 13 Sep 2016 at 9:18pm |
I just got a g160 engine. Is there anything you can do to these engines for more power? Piston/sleeve kit or possibly flattop higher compression pistons?
dgerth
Posted: 13 Sep 2016 at 10:23pm |
I am no guru on AC stuff but I upped the cr to 12.7:1 by changing the pistons and milling them down a mite. Made a 4 -6 mph "giant killer" out of it. We are quite happy with the way it pulls and have the proof hanging on the shop walls. You won't be sorry!!
dan
1955allisca
Posted: 14 Sep 2016 at 6:05am |
What kind of pistons did you use? I have a g149 in it right now and it has loads of power I just like overkill I reckon
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5475 |
Posted: 14 Sep 2016 at 8:16am |
After you get it going, travel over my way to pull with us, we need some more 2500 pound tractors. What Dan has done is about all you can do without going the turbocharger route, for that 160 just the way it is works great.
Posted: 14 Sep 2016 at 10:05am |
Quick easy HP ?? Use 93 octane gas and advance the timing to 30 degrees BTDC at wide-open throttle. Remove the carb and install the larger 175 venture or swap out for the larger D-19 style carb. Hog out the intake throat above the carb if needed. These two things(D-19 carb and fuel/timing) could add 6 to maybe 10 HP without ever tearing the engine apart.
1955allisca
Posted: 14 Sep 2016 at 10:31am |
Will flattop pistons clear?
Posted: 14 Sep 2016 at 11:16am |
Sure, if they're not too tall. As long as they aren't any taller than the outer edge of the Power Crater OEM pistons they'd be fine.
1955allisca
Posted: 15 Sep 2016 at 8:36pm |
Does anyone know the measurement from top of wrist pin hole to top of piston on stock g160 piston I think I found some pistons that will work
Posted: 15 Sep 2016 at 10:15pm |
G-160 piston pin is one inch diameter, not .990" like G-149.
1955allisca
Posted: 15 Sep 2016 at 10:41pm |
Do you know measurement from top of wrist pin hole to top of piston? I am trying to figure out if these flattop pistons I found will come up as far as the power craters
