B engine |
john2189
Joined: 11 Sep 2009 Location: Minerva,Ohio Points: 514 |
Topic: B enginePosted: 5 hours 8 minutes ago at 10:16am |
How do you get the crank pulley off? Got the setscrew out. Tried a couple wood wedges. Wont budge. Doesn’t look like a 3 jaw puller will work. I don’t want to ruin it.
And what do you use to get the nut on the setscrew loose? I used a chisel, it wasn’t that tight. |
'41 Allis B
'49 Farmall Cub |
mdm1
Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2732 |
Posted: 4 hours 28 minutes ago at 10:56am |
I got a large bearing separator from HF and used that as a puller. Worked good. You have to be careful not to damage the pulley.
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9269 |
Posted: 2 hours 30 minutes ago at 12:54pm |
That isn't like my 45 and has 2 set screws in that hole? One on top of the other. I don't think they are a tight/drive fit so some penetrant should help.
Edited by SteveM C/IL - 2 hours 29 minutes ago at 12:55pm |
Les Kerf
Posted: 1 hour 23 minutes ago at 2:01pm |
Yup. My Model C had two setscrews in the same hole. I also use a bearing separator type puller on those
