Trouble with the M3
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Topic: Trouble with the M3
    Posted: 24 Oct 2026 at 4:26pm
Chunked a bearing on the main shaft and I see the bearing housing is cracked
Is there a trick to removing these pulleys?
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2026 at 5:08pm
Ive got a L3 that looks just like that and ive had that pulley off to put bearings on the main shaft. I didnt have any problem getting it off. If you decide to use heat id be very careful with it. I dont know how much heat the laminations in that header clutch coil will stand
Good luck
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2026 at 5:54pm
My assumption is after removing three bolts off the main pulley, it would just pop loose. The 3 jaw puller has a lot tension at the moment. Figured I could heat near the center if that's all it takes then tackle the clutch. I know a guy near Preston, may have bearing housing
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2026 at 6:45pm
Screw the 5/16s bolts that you took out into the other holes and it will push off quite easily. Blow the holes out first, plenty of lube, and alternate the tension.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2026 at 10:22pm
Lynn has your answer. My F2 is like that. Once you figure it out it's a breeze. Probably in the service manual which nobody has....
The engineers were thinking. When i do a mainshaft brg, I do both sides. That other one has as many hrs on it. When I got my 4000hr R62 I wish i'd sent it to the shop for PM and had new main brgs installed. A couple years in it ate the rt side and of course spun on shaft and ruined it. Would have been half price or less. Think that shaft was around $3500.
Edited by SteveM C/IL - 24 Oct 2026 at 10:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2026 at 11:50pm
Kinda wondered if that was case. I did try that but bolts didn't seem to do anything. I'll clean it out good and try again. Thanks
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2026 at 11:01am
I would use sacrificial bolts to pull with,, or better yet,, new ones when ya go back together
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2026 at 12:11pm
To push with I'd get grade 8 bolts and grind the ends off just a little so when they mushroom it won't be an issue backing them out
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2026 at 1:05pm
So this morning we went back and blasted some air into all the holes and sure enough there were threads to engage in as Lynn had stated. Lube and sent the bolts in. Got really really tight. My thread chasers aren't long enough reach in and I thought they were bottomed anyway. Mind you the 3 jaw is still in place. Next I brought out the torch and gave it 3 heat cycles. Went and picked up walnuts for while allowing it to cool. Began the tightening sequence again along with the 3 jaw and all were really tight again then noticed one bolt turning more than the others when POP!! The whole works jumped off and hit the ground. This is a tapered hub and bushing assembly. On closer inspection, two bolts never passed through .the hub. The threads were not clean enough. Now down the inner hub and need a different puller.
Back at it after lunch
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2026 at 1:16pm
Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2026 at 9:16pm
Once the magnet and armature are removed, I just used a pair of 1/2 inch redi rods and a plate to pull the small header drive pulley off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2026 at 9:19pm
Could not find my bigger puller. Made do with current setup
Busted housing and outer race pried off easy enough but that inner race pushed my buttons. Hot wrench finished it. Against my wishes we proceeded to remove like assembly from another M3 we have. Knowing what we know now, not nearly as much effort to remove. Currently at the main bearing and good housing. Building a different puller to use the threaded holes in the housing to pull. Family stopped by for visit so we got squirreled. Will resume tomorrow
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2026 at 9:22pm
Lynn, yes I considered that but didn't want to stop and fab something. In the end that's what I'm doing for the housing. Will update
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2026 at 7:26pm
Found a piece of 1x3 iron 7" long to use for my puller. This only accommodates two of the four four bolt holes in the housing. I a piece of 1x3 tube iron for the other bolts. Drilled the needed holes cut the needed all thread and proceeded to pull. The tube collapsed and the other two all threads stripped in the nuts. Shut down till I get more all thread and better chunk of iron. Or, buy another housing my parts guy found. Pretty pricey IMO but maybe concede defeat
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 52 minutes ago at 7:53pm
So I tucked tail and got the housing from my parts guy. And a new bearing. Putting it back together. On the tapered hub and main pulley is there a torque spec for those 3 5/16 bolts? Pretty sure they need evenly tightened
Some general charts I'm reading have it at 17ft/lb for grade 5 dry
Edited by plummerscarin - 20 hours 48 minutes ago at 7:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 43 minutes ago at 8:02pm
A online torgue chart should give you a spec for whatever grade bolts they are. That shoukd get you close enough. Since its a taper i think id check them again after you run it a little
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 31 minutes ago at 9:14pm
antiseize and a 6 in 3/8 drive ratchet will get you all you need.Just good and tight for a 5/16 bolt. They will not loosen and will hold just fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 57 minutes ago at 3:48pm
It's rather amazing that those 3 little bolts that hold the big pulley onto the tapered hub are literally driving the whole machine. The tapered hub is keyed to the shaft, but the pulley isn't keyed to the hub. I've never seen a failure of that design on the gleaner.
