7060 question |
Wot
Topic: 7060 questionPosted: 25 Oct 2026 at 2:51am |
Hello, yesterday I noticed that although the tractor was in gear—and correctly set to the high range—it wouldn't move forward when I released the clutch. After a short wait, it finally engaged (the gearbox did grind when shifting into gear, so I don't suspect the clutch is the issue).
Furthermore, I notice this happening primarily when the tractor is positioned on a downward slope (nose pointing down); on one occasion, the hydraulic high-low even shifted into the low range on its own while driving downhill. Could this be caused by low oil levels in the "power director" (transmission/range unit), or is there another underlying cause? During normal operation, I don't notice any issues, and the tractor has its usual power. Thanks! |
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2561 |
Posted: 25 Oct 2026 at 10:13am |
Certain sounds like low oil in transmission. The transmission oil pressure light should have been on,if that is the case. Does the light even work?
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 935 |
Posted: 25 Oct 2026 at 3:24pm |
By what you first described im wondering if your hi low cable on the range transmission is worn out stretched or out if adjustment. When it would not move then ground then fell into gear is not good. You need to know its fully egaged
1984 80780
Posted: 26 Oct 2026 at 4:07pm |
Transmission oil (dipstick in the cab) is a couple gallons low on oil. Also, 1800 light isn't working either.
8070nc
Posted: 26 Oct 2026 at 7:45pm |
I miss read what you said happened
1984 80780
Wot
Posted: 50 minutes ago at 4:20am |
Perfect, thanks for your answers. Will add oil in the cab.
