Poor Man’s…………… |
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8590 |
Topic: Poor Man’s……………Posted: 13 hours 33 minutes ago at 8:46am |
radiator repair.
2009 Ford Explorer, top portion of radiator is black ‘plastic’, small crack on very top of dome, about an inch long, about 2 inches left of the filler neck. The crack is more pronounced when radiator is hot. Is there a process to patch this crack? TIA. |
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 5023 |
Posted: 11 hours 6 minutes ago at 11:13am |
I have one out of Ford Ranger pickup with 3 liter you can practice on.
I was going to play with it never got there. NAPA had replacements for $120 about 10 years ago. I do have an account with them that has a decent discount on it, but don't know just how good.Still have 2 of the pickups with the 3 liters. Nether gets many miles lately.
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 5032 |
Posted: 9 hours 57 minutes ago at 12:22pm |
Iused this on my daughters
Kia 3-4 years ago for a crack, still holding |
Allis Express North Georgia
Lars(wi)
Posted: 9 hours 38 minutes ago at 12:41pm |
I will check this out, it’s on the radiator itself, not the overflow tank.
Edited by Lars(wi) - 9 hours 37 minutes ago at 12:42pm |
wjohn
Posted: 8 hours 36 minutes ago at 1:43pm |
I used JB Weld 20 years ago on my Civic's radiator, where one of the little nubs that mounts the radiator into an isolator on the body snapped off previously during a front end collision. That left a pencil-sized hole in the top of the radiator.
That repair held, but slowly seeped, for about 15 years. Then about 5 years ago I had to redo it. Then again about a year ago. The issue was the JB weld not bonding well enough with the nylon (or whatever) radiator tank material and it would slowly lift off of the tank plastic. The last time I made sure to drain the radiator enough to get the coolant level below the hole, clean it very well, dry it, and then redid the repair... it hasn't leaked a lick since. Not something I would use brake cleaner on (terrible for plastics) but I want to mainly stress you need to get the surface you are bonding to as clean and dry as possible. On the flip side, I recently had a crack in the end/side tank of my Ram diesel, which isn't an uncommon issue as they get up to 20+ years old... and I looked at the crack and decided it was not worth attempting to repair because I didn't expect any repair to hold the way it was splitting out in several directions. If it were just a farm truck that never went further than 20 miles away I might have given it a shot, but some cracks are going to keep spreading and it is just a question of when it decides to fail on you again. One of the issues is that the radiator itself experiences 16 psi (or whatever your cap is rated at) of pressure over and over and over again, plus the temperature. My vote is if you don't take the vehicle a long ways from home go for it. Otherwise I'd spring for a new radiator.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5475 |
Posted: 4 hours 29 minutes ago at 5:50pm |
It's a Ford, to fix that you jack up the radiator cap and put a new car under it right
Ray54
Posted: 3 hours 36 minutes ago at 6:43pm |
I have friend that use to tell that every time asked for his help fixing something. And he is a Ford guy still. J_B weld would my first try on some thing like this. But have not kept up maybe something newer is better. But have 20 year old patch on a fuel transfer tank.
plummerscarin
Posted: 3 hours 1 minutes ago at 7:18pm |
Ever try plastic welding? If you get the heat right you may be able to close the crack. Did this on a plastic fuel tank for my Cub Cadet zero turn. Of course that one is never under under pressure.
Joined: 11 Sep 2009 Location: illinois Points: 93430 |
Posted: 2 hours 49 minutes ago at 7:30pm |
most of the "repair kits" are basically an epoxy base with a small fiberglass patch to span over the crack.. That could help compared to straight epooxy or JB weld... You might actually try drilling a 1/8 inch hole on each end of the crack to stop it from growing everytime the tank goes under pressure... you got nothing to loose.. Take a burr grinder or coarse sandpaper and rough up the area first to get a better GRAB onto the tank.
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 56132 |
Posted: 1 hour 28 minutes ago at 8:51pm |
Reminds me of that old Daffy Duck cartoon:
